73 battery ground cable
Installing a new battery ground cable with a large rubber grommet that inserts into the battery compartment bottom. This hard rubber grommet is larger than the hole. I have tried dish soap, WD40, white lithium grease and even Vaseline. The grommet just seems too large for the opening. Can anyone explain how to get this grommet into the bottom hole?
Which direction are you installing it ? It only goes in 1 way. It appears to be larger than the hole but the groove inside is not (if your car has not been altered),its designed this way to seal out moisture.
FWIW, I definitely would NOT enlarge the hole. That's a permanent change to the car, and one that, once the grommet's in, you may regret. The grommet/floor pan seal needs to be water tight. Before reducing the size of the grommet, I'd spend more time trying to get it inserted. They are very tough (don't ask me how I know ).
I used vaseline and a load of "push power", finally getting it to go in on one side. Then, I worked it around, little by little, turning it in place. You'll struggle, but I'm confident you 'll get it. One of the more difficult jobs I've done. I had the advantage of a lift, so the angle for pushing might have given me an advantage over laying on my back.
Good luck with this project.
Did I mention how tough this job is for such a small task? I'm having flashbacks just typing about it...
Very helpful hint from somebody else who did this; it takes 2 people. One inside car pushing down and keeping grommet from moving around. One underneath pulling down with channel locks. Use lots of vaseline around the hole before doing this. It took about a half-hour; that included jacking up the car and putting it on jack stands. This works!
I'm curious if you folks are installing the grommet and cable both at the same time? Or the grommet just by itself won't install?
A tool like this radiator hose puller might help:
73 Battery Ground cable
Cable and grommet are sold together. Cable has coonectors crimped on both ends so that the cable does not slide through (we checked). A buddy works best!
