breaking exhaust slip-fitting
Old Jul 27, 2012 | 09:07 AM
jnb5101's Avatar
jnb5101
Default breaking exhaust slip-fitting
is there a method to break down an exhaust system at the slip-fit joints?
Old Jul 27, 2012 | 09:35 AM
JimT's Avatar
JimT
I've soaked the joint with penetrating oil, or heated them, and used two pipe wrenches to wiggle them loose.
Good luck!
Old Jul 27, 2012 | 10:08 AM
Crash80's Avatar
Crash80
Brute force and ignorance.... that is how I did last time I had to do it.
Old Jul 27, 2012 | 10:54 AM
69 Chevy's Avatar
69 Chevy
Oxy-acetylene or oxy-propane rosebud flame played on the joint and then tapped with a hammer to break the rust weld joint. Twist and pull to remove.
Old Jul 27, 2012 | 12:38 PM
jnb5101's Avatar
jnb5101
thanks
To breaking exhaust slip-fitting
