Another Procomp head question SBC cast head
Old Jul 28, 2012 | 12:53 PM
Slowlock's Avatar
Slowlock
Cruising
Default Another Procomp head question SBC cast head
I did read here that a lot of guys do not like the pro Comp aluminum heads. I have also read that some people felt they were not bad for the money. Has anyone tried the cast iron heads? http://www.ebay.com/itm/NEW-GM-CHEVY...item2a1cfe6c52
I don't want to buy junk. I also do not want to put money into my 882 heads. I don't hear good things about them either. Unless someone has actually had good results with the Cast Pro comp heads I won't buy them. I'll wait for a good deal on a used set of heads comes around.
Old Jul 28, 2012 | 01:01 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
[QUOTE=Slowlock;1581426854] I don't want to buy junk.[/QUOTE ]
Then don't buy Procomp. There are a lot of quality aluminum heads for under $1000. Why buy used heads and pay to rebuild them. You will be close to new cost. Save up and buy the right heads for your build. If your looking at iron heads Dart Iron eagles or Vortec.
Old Jul 28, 2012 | 01:30 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
See if you can find out who makes the heads, no-one except one guy (S.W.) on ebay seems to know exactly which part of China they are made.
Like stated above, good advice
Old Jul 28, 2012 | 01:38 PM
superdave269's Avatar
superdave269
I have been steered away from these heads. I haven't used them but think I'll go with Dart heads. From what I'm told their better heads and not for a lot more money.
Old Jul 28, 2012 | 06:30 PM
bluedawg's Avatar
bluedawg
I believe it was either chevy high performance or car craft last month that did a dyno comparison of heads under 1000$ procomp didn't do as well as other heads in the same price range which is no wonder considering that the comunist chinese don't build hot rods. it was actually a good read. If you could save up for a while longer & bought a set of afr's you'd never be wondering what kind of performance that you lost out on.
Old Jul 29, 2012 | 03:15 AM
Shark Racer's Avatar
Shark Racer
ell oh ell $200 heads? I paid probably close to that much for soft parts when I do a head swap... wow.
Next up - how to make cometic head gaskets with aluminum foil and two sheets of freezer paper!
To Another Procomp head question SBC cast head
