help me troubleshoot....
Old Jul 29, 2012 | 08:08 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
Default help me troubleshoot....
i'll try and keep it short and sweet.
engine: rebuilt L-48 headers and a mild cam.
i had a holley 750 on the motor and was always adjusting and i had a hot re-start issue. (which i think was my battery) new battery installed.plus if i had the idle set a little high i would get pre ignition on shutdown. i was told to try an edelbrock so i went and got a 600cfm. car ran ok for awhile then started to act up. the car slams into gear and the rpms drop very low and wants to stall. my mechanic told me the carb was no good "send it back". i did. put the new one on. same thing.... timing was checked carb was adjusted and it still not running good. vac. advance was disconnected and is running a little better...
why is the car slamming into reverse and drive??? drive is not as bad as reverse.
why is the rpm dropping so low when put into gear???
i need some help.....
Old Jul 29, 2012 | 08:23 AM
wombvette's Avatar
wombvette
Too much cam for a low stall torque converter. Or vacuum advance wrong for the set up, causing it to fall out when rpm falls as it goes into gear.
Old Jul 29, 2012 | 11:38 AM
hdpete98's Avatar
hdpete98
95% of carb problems are electrical (I just made the percentage up but you get my point). Hot start problems are usually the timing to far advanced. Make sure distributer is tightened down. They can move causing the timing to advance over time. This would explain car initially being fine and then problem arising over time.
Old Jul 29, 2012 | 09:31 PM
thiatt's Avatar
thiatt
The vac line to tranny is disconneted or leaking is my guess. Causes hard shift vac leaks cause stalls.
Old Jul 29, 2012 | 10:34 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
consider this......your vacuum cannister is not pulling in full vacuum because of the cam change. so your idle is incorrectly set high and then when you put it in gear the rpm drops down and the vacuum advance cutrs out dropping the rpm even lower.
lets test this....take a vacuum pump with a gauge and hook it up to the distributor and see when the vacuum advance pulls in....
then use a vacuum gauge and see what vacuum you are pulling at idle. your vacuum advance should pull in fully before you hit about 3/4 of your idle reading. Lars papers explain this and will give you the right cannister nunmbers so you can fix this.
Old Aug 7, 2012 | 08:00 AM
79 vette head
St. Jude Donor '10
finally spoke to the edelbrock tech on the phone. he is suspecting too much fuel pressure...causing the car to load up with fuel.
Old Aug 7, 2012 | 09:18 PM
bobs77vet's Avatar
bobs77vet
??????????? i think you better call again , this doesnt pass the smell test.
Old Aug 8, 2012 | 09:49 AM
69 Chevy's Avatar
69 Chevy
What advice did your mechanic suggest after the new carb made no difference?
To help me troubleshoot....
