Temp fix to headlights??
I have a 69 vette.. All of a sudden my head lights have errected and wont go back down.. There NOT on just up and it drives me crazy!! Is there a temp fix to get them to go back down?? I dont drive it at night so im not worried about that.. I guess i will be back on here to try to find a fix unless someone has any ideas im all ears
There should be a little thing-a-ma-jig under the dash, right below the steering wheel, called the override switch. When pulled down, it keeps the headlights from going down, even when the lights are turned off. There should be two of them, the other is for the wiper door, I think. That is the first thing I would check.
http://forums.corvetteforum.com/c3-t...tem-works.html
Keep the shiny side up!
Scott
Scott
Reach up from underneath the front bumper. You will see the spring mechanism that operates the light assembly. Pull down gently and the door will close. You do not have to pull hard and the springs will do the work. If you are pulling hard, you are pulling in the wrong area. Just take a look and it will make sense.
Ahh! Well, you didn't tell us that before! I guess we'll have to play "20 questions". Don't feel bad, it can be tough to tell what's important and what isn't, sometimes.
When did the headlights pop up and not go down? I don't mean, like, what was the date, I mean was there anything that you did, and then the headlights started acting up? Even if you think it is unrelated? Have you studied the link I posted? It does a pretty good job of explaining how the headlight actuation system works.
Scott
Scott
UPDATE
I checked it out i was able to get the lights down and as soon as i started the car they went back up.. Undernearth it looks like a HOSE is off or it has broken off. I havent had time to investigate much further for i had my 2 kids WAITING for their corvette ride!! Sorry for the lack of info..
