69 non power Brakes
Old Jul 31, 2012 | 10:03 PM
Lemans Blue 69's Avatar
Lemans Blue 69
Default 69 non power Brakes
1969 Corvette w/o power brakes. Had them redone. The car stops driving normally but full pressure on the brake pedal will not lock the wheels. Is this normal?
Old Jul 31, 2012 | 10:31 PM
gcusmano74's Avatar
gcusmano74
You should be able to lock the wheels on a panic stop. With non power brakes, and modern (very grippy) tires, the pedal effort required is quite a bit higher than a power brake.
Does the brake pedal feel firm? The brake system on C2's and C3's has to be carefully bled. Any sponginess is likely caused by some air in the system. A brake hose that is about to fail can also make the pedal feel soft.
First the master cylinder, then the calipers.
If you get a firm pedal in the garage, and the pedal falls away as soon as you drive it, you have runout issues. Maybe the wheel bearings are loose, or maybe the brake disc is warped or not quite flat on the hub.. Years ago, outfits like SSBC sold shim plates to address rotor runout caused by rotor/hub mismatches..
Old Jul 31, 2012 | 11:44 PM
Lemans Blue 69
Let me rephrase my question. Anyone own a 1969 Corvette with non power brakes and can lock their wheels on a hard brake. Sorry, but "SHOULD BE ABLE TOO" is not the answer I was looking for. It's either yes or no? From factory.
Old Aug 1, 2012 | 05:56 AM
Alan 71's Avatar
Alan 71
Hi LB69,
In that case... Yes!
Regards,
Alan
Old Aug 1, 2012 | 07:41 AM
CFD E59's Avatar
CFD E59
"YES", I can lock mine up..
70 Big Block Non-Power Brakes.
Were your brakes warmed up? Cool/ Cold brakes are not as efficient.
Old Aug 1, 2012 | 12:20 PM
bashcraft's Avatar
bashcraft
I can't lock mine up, and I've tried. I still need to check and see if I have the correct master cylinder. I replaced it awhile back and don't know if they gave me the right one.
Old Aug 1, 2012 | 04:32 PM
Lemans Blue 69
Brakes were warm. Guess I need to find out why they don't lockup. Thanks for the responses.
To 69 non power Brakes
