Idle high in neutral
Old Aug 1, 2012 | 07:11 PM
rmowens@roadrunner.c's Avatar
3rd Gear
Default Idle high in neutral
1971 roadster frame off resto. idles fine in "D" 750rpm startsout OK in neutral wen it warms up the RMP will go up to 12 or 14 hundred. I am leaning towards the choke? Any ideas??
Old Aug 1, 2012 | 10:11 PM
1986coupe's Avatar
1986coupe
Check for vacuum leaks and check the choke.
Is the timing set right?
Old Aug 2, 2012 | 09:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Fast idle backing off when you tap the accelerator pedal?
Old Aug 2, 2012 | 10:16 AM
Mike Ward's Avatar
Mike Ward
Since you're 'leaning towards the choke', have a look to see if it's wide open when the engine is warmed up.
To Idle high in neutral
