Help ID Holley Power Valve
Old Aug 2, 2012 | 07:48 PM
PeteZO6's Avatar
PeteZO6
Default Help ID Holley Power Valve
I have a Holley power valve I am trying to ID. My 4150 DP came with a 65 power valve, which I replaced with a 75 valve. On a subsequent teardown I THINK I put the original 65 back in.
My Holley book shows the numbers stamped on the flat sides of the casting, but this one has numbers on the steel plate on the back/front. There is clearly a 7 and a 5 on one side, and also a H and 6 on the other side which I believe is the date of manufacture.
Depending on how it is read, this could be a 65 valve dated H 7, or a 75 valve dated H 6.
Anybody?
TIA, Pete
Old Aug 2, 2012 | 08:01 PM
nitrojoe's Avatar
nitrojoe
Default Power valve info
Good info :
http://www.rodsnsods.co.uk/forum/tec...alve-i-d-20341
Old Aug 2, 2012 | 08:22 PM
PeteZO6's Avatar
PeteZO6
Originally Posted by nitrojoe
Very good info. From the video example, the power valve in the photo above is a 75 or more correctly, 7.5. That's the answer I was looking for.
Thanks,
Pete
To Help ID Holley Power Valve
