Engine Won't Start... Sometimes
Old Oct 19, 2012 | 09:45 PM
Tommy 73's Avatar
Tommy 73
I am having the same thing, if it is the starter, will you be able to start
it with a screwdriver, I can my
Tommy 73
Old Nov 3, 2012 | 12:53 AM
Mariana's Avatar
Mariana
Are you running HEI Ignition? If so, what is the power source, should be off the fuse box. check for connectivity. Happened to me. I replaced dist, rotor, cap, coil, module. And lastly looked to see the hot wire was loose, may have my kicked by my foot.
Old Nov 3, 2012 | 09:33 AM
74modified's Avatar
74modified
Tommy 73
The coil, rotor, ect have nothing to do with the starter turning. If you use a screwdriver to short across the solenoid large battery terminal to the S terminal, and it cranks - your ground is working. Your battery cable to the starter is working. The starter is working. What you are bypassing, is the start circuit - key switch, neutral safety or clutch switch, wiring ect. That said you could still have a bad battery or cables that reduce the voltage going to the solenoid by the time it runs through all of the start circuit. It can be a combination of things, weak solenoid + bad connections ect. Go back through the thread, get a volt meter, start at the battery and work forward to you find the problem. It helps if you have a wire diagram.
