Overheating after alum radiator install
#41
Well both fans are blowing in the correct direction (towards the engine). But I am still having to fill the radiator with coolant. This makes 4 times, and I seem to lose about 1/2 gallon for every 20 minutes of driving time. Either I have one big air pocket or my heads are cracked. The temp seems to be ok, until it approaches the 20 minute mark, which is when the radiator gets low.
No leaks? are you pumping steam out the tailpipes?
Do a leakdown compression test. I would worry about hydrolocking a cylinder and trashing the engine if you are losing that much coolant.
Maybe some of our engine experts can chime in but souinds like you should not be running it to me.
#43
Wow! I am surprised its even running correctly. thats alot in 20 minutes of driving. Its either leaking out,burning out thru the exhaust, or filling your oil pan.
#45
I actually resolved this problem quite awhile ago, it was a very small pinhole on the upper radiator hose. I cut about 1" off the end and all is good. There were multiple problems though, it still overheated after that, it just didn't lose any coolant. The other problem was resolved when I pulled the old intake off to replace it with the RPM Intake. There was junk built up in the intake coolant passage ways. So much so, that it blocked the entire passageway. I have a 160 deg thermostat in it now, and that is what it runs at, all day long....
