Bad distributor coil?
Old Jan 19, 2013 | 01:53 PM
Doug1's Avatar
Doug1
Default Bad distributor coil?
Hey guys, I got a new distributor a few months ago which didin't include the coil so I swapped the coil from my old dizzy. I'm having backfire through carb issues that I can't resolve. New holley 750 double pumper and new fuel pump. I've tried various timing settings, to no avail. I'm wondering if the new parts in that dizzy went bad already(Accel, $125 at auto parts store), or if maybe the coil is "bad". I thought coils pretty much either worked or they didn't. any thoughts? the wires are only about 3 months old and they are routed correctly. 78 with HEI btw
thanks
Old Jan 19, 2013 | 04:38 PM
Doug1's Avatar
Doug1
I just swapped coils and same, swapped out dizzy with an older one that I know works, no improvement, tested fuel pressure, 7ish...checked again for vacuum leaks with a cigar and smoke. ready to blow this car up.
Old Jan 19, 2013 | 06:45 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Firing order correct?
Old Jan 19, 2013 | 06:56 PM
Mike Ward's Avatar
Mike Ward
Bad cam lobe, burnt intake valve.
Old Jan 19, 2013 | 08:13 PM
Doug1's Avatar
Doug1
yes, checked multiple time.thanks
Old Jan 19, 2013 | 08:14 PM
Doug1's Avatar
Doug1
hope not, ok, thanks
Old Jan 19, 2013 | 08:18 PM
Doug1's Avatar
Doug1
I ran the engine awhile with the valves too tight, could this cause intake valves to get burned?
Old Jan 19, 2013 | 08:34 PM
Doug1's Avatar
Doug1
http://forums.corvetteforum.com/c3-t...rnt-valve.html
post #6, well as long as I lay off full WOT I'm pretty safe, stock 882's anyway, I'll start saving for some aluminum heads like a pair of Edlebrocks
To Bad distributor coil?
