4 speed swap almost...
Old Aug 4, 2012 | 07:20 PM
lowes-yellow77's Avatar
lowes-yellow77
Default 4 speed swap almost...
First to the guys that have done the swap, i give you alot of respect, some things were a complete bit(ch.
I do have a few questions though, i took it for its first test drive, i was real easy on it knowing that it needs some break in time.
i had a small smell of clutch after about 5-7 miles driving. I didnt smell it until pulling in the driveway though.
Second questions i have a small faint squeal noise only when clutch is engaging (clutch pedal coming up) and only when in gear. It did get more faint from leaving driveway to coming back after the 5-7 mile drive.
Third i cant get the speedo cable hold down on trans to fit, cable goes in and speedo works, im sure they are different for auto and manual, part number?
Any help guys thanks
here is the parts list
1. 69 muncie trans. $600( online) (with receipts from shop)
2. 621 bellhousing $125(swap meet)
3. pedal assembly and linkage to clutch for $175 shipped(from here)
4. flywheel 456N $10(back of blazer in junk yard) ($35 to resurface)
5. clutch fork $70 (ebay)
6. lower shift boot $25(ebay)
7. clutch 11inch $135 (NAPA) NAME BRAND LUK
8. hurst shifter 20$ swap meet ( clean and put back together 1 hr labor
9. hurst shifter install $145 (summit) part number 3738611 for late 60`s-- early 70`s
10. hurst shifter handle $72 hurst part number 538-7991 for 77-82 only
11. hurst back up light switch $25.(summit)part number 2480003
12. z bar bracket $14(zip corvettes)
13. z bar rebuild kit $34
Old Aug 5, 2012 | 07:47 AM
bt57's Avatar
bt57
Default clutch
sounds like (smells like) the linkage is binding up or the pedal not returning all the way letting the clutch slip.
it is a tough job to this conversion-woth it when done.
Old Aug 5, 2012 | 09:57 AM
69 Chevy's Avatar
69 Chevy
I don't know...seems like an awful lot of trouble, not to mention expense, to do the shifting for yourself.
Old Aug 5, 2012 | 10:31 AM
Alan 71's Avatar
Alan 71
Hi l-w77,
4 Speed.... VERY nice! Well worth the effort.
I looked in my 71 AIM and the speedo cable retainer at the transmission is # 3708148. There's also a seal shown, #3708146.
I don't know if that will help on your 69 muncie. Maybe?
I'm sorry I'm not enough of a mechanic to help with the rest of your questions.
Good Luck!
Regards,
Alan
Old Aug 5, 2012 | 10:49 AM
lowes-yellow77
BT57
It may have been pedal linkage, but no more smell now. Just need to mold sheet metal for hole and install lower shift boot and the swap will be done .
69chevy
Some of like to shift our own gears
Old Aug 5, 2012 | 11:30 AM
69 Chevy's Avatar
69 Chevy
Originally Posted by lowes-yellow77
69chevy
Some of (us) like to shift our own gears
I do too! But an overwhelming amount of C3 forum members genuflect at the alter of an auto trans, they can't all be wrong. Can they?
Old Aug 5, 2012 | 11:51 AM
lowes-yellow77
Alan 71 thanks, thats exactly what im looking for.
69 Chevy, didnt mean any disrespect, i looked and looked for a 4 speed when i bought mine but it seemed like they had dried up so i bought a auto car and saved for 3 years to be able to get all the parts (military doesnt pay all that well) for the 4 speed swap, i did look into the 5 speed W/C trans but they wanted a small fortune it seemed, i live on a island and the top speed as per speed limit is 55 mph.
I know now how to do the swap and where short cuts can and cant be taken, hopefully i can help people in the future on here.
Old Aug 5, 2012 | 12:03 PM
Duane4238's Avatar
Duane4238
I'm partial to the 4 speed, too. I can't imagine having an automatic in a Vette. I guess it comes from the generation I'm from. Back in the day, the ones driven by guys were 4 speeds and the ones driven by someone's mom were autos. My DD is an auto, but for fun, nothing beats shifting!
Duane
Old Aug 12, 2012 | 08:47 AM
power shift's Avatar
power shift
I did a 4 speed swap and when I pushed in the pedal down I got a squeel too. I found the problem. I had the clutch fork in the wrong slot in the throw out bearing. Fixed it and it works fine.
Old Aug 12, 2012 | 01:43 PM
lowes-yellow77
Well a update guys car is great, smell was rear brakes I overtightened the emergency brake cable and they were dragging, ceramic pads smell a lot like a clutch, noise is gone too. If only the corvette shops around the world knew there were corvette experts on this site, they might get on here just for help.
To 4 speed swap almost...
