starter wire (S)
Old Aug 10, 2012 | 07:10 PM
northern77's Avatar
northern77
Default starter wire (S)
Help, I would like to know where the small (s) wire on the starter silenoid leads to, is it the neutral safety switch? Thanks
Old Aug 10, 2012 | 07:30 PM
Peterbuilt's Avatar
Peterbuilt
Default Yes!
Old Aug 10, 2012 | 07:46 PM
northern77's Avatar
northern77
Thank you Sir!
Old Aug 10, 2012 | 11:11 PM
TimAT's Avatar
TimAT
C'mon there pete- these wiring diagrams HAVE to have so many wires on them it's near impossible to track one wire thru them. GEEZ, anyone can follow that one!!
Old Sep 9, 2012 | 02:38 PM
STL 71 C3's Avatar
STL 71 C3
how would I go aout wiring this starter with above diagram?
Kind of confused here because new starter does not have the third terminal for wire going to distributor..
Old Sep 9, 2012 | 08:24 PM
my 76 ray's Avatar
my 76 ray
I'm not sure that will work with a points ignition.
Old Sep 9, 2012 | 10:43 PM
STL 71 C3's Avatar
STL 71 C3
Not points....HEI
Why would starter make a diff?HUH????
Old Sep 9, 2012 | 10:58 PM
'75's Avatar
'75
77 would not need or have the dist wire from the starter. The purple wire comes from the neutral safety switch and goes to the s terminal on the starter.
Old Sep 9, 2012 | 11:01 PM
STL 71 C3's Avatar
STL 71 C3
my car is a 71, original points car but now HEI
Old Sep 9, 2012 | 11:08 PM
'75's Avatar
'75
Oops, I thought you were the original poster. Just leave the R wire at the starter unhooked and tape it back.
Old Sep 9, 2012 | 11:25 PM
STL 71 C3's Avatar
STL 71 C3
then what goes to the distributor?
Old Sep 9, 2012 | 11:50 PM
TimAT's Avatar
TimAT
Your 71 originally had 2 wires to the + side of the coil. One from the starter "R" terminal and one from the ignition switch. THe one from the switch has a resistor in it and can't be used with HEI. The one from the starter suppled a full 12v to the coil for engine start and is normally not powered, although it does have 12v fed from the coil+ connection when the key is on.
Old Sep 10, 2012 | 08:14 AM
'75's Avatar
'75
HEI requires a 12 ga wire from an ign source such as the ign tap in the fuse box. Do not use the resistance wire that was powering your old coil because it won't provide enough power to the hei. As Tim said, the other coil wire that used to go to the starter R terminal is not used either.
To starter wire (S)
