front add on bar
Old Aug 11, 2012 | 10:41 AM
scrappy76's Avatar
scrappy76
Default front add on bar
I have seen a couple vettes in here with a pic of a bar that ties the upper A arms together for front end stability. Whats it called and who sells them ?
Thanks.
Old Aug 11, 2012 | 12:13 PM
pauldana's Avatar
pauldana
Thanks.
Spreader bar
http://speeddirect.com/index.aspx?nodeID=183
mine is red...... yes it helps...
Old Aug 11, 2012 | 12:37 PM
69 Chevy's Avatar
69 Chevy
I bought large Heim ends and threaded tubing at a race car shop. I fabricated the upper control brackets myself because I wanted the Heim end bolts to be vertical rather than horizontal. I don't have the OEM fan blade to work around anymore. Sturdier construction and less expensive than the ready-made spreader bars.
Old Aug 12, 2012 | 01:35 PM
MyRed69's Avatar
MyRed69
Vansteel has them too:
http://www.vansteel.com/index.cfm?fu...&SubGroup=1936
Old Aug 12, 2012 | 04:33 PM
MN80Vette's Avatar
MN80Vette
Thanks.
It is called a spreader bar.
I bought mine from Vette Brakes & Products. They offer two options. One is pre-welded for cars without a mechanical fan, like my '80.
1963-82 Pre-Welded Spreader Bar Kit
They also offer an unwelded version for cars with a mechanical fan.
I HIGHLY recommend this add-on. It makes a noticeable difference in the stiffness of the frontend in general.
Old Aug 13, 2012 | 06:54 AM
scrappy76's Avatar
scrappy76
Thank you all very much. And good to know it does help and that its just not a pretty add-on.
Old Aug 14, 2012 | 09:17 AM
scrappy76's Avatar
scrappy76
Well I should have read deeper. this add on is for small blocks only unless your bigblock has an electric fan. Well I do have a big block in my 76 and I do have an electric fan. Anyone here have a pic of the spreader bar installed with a big block with electric fan ?
Old Aug 14, 2012 | 11:02 AM
oldalaskaman's Avatar
oldalaskaman
http://www.google.com/url?sa=t&rct=j...H8mGi_8YgrwpjA
hope this helps. seems that with an electric fan, any of them will work. if you check the location of his weld on mounts, they are behind the c/a bolt. with out the mech fan, you could even use the weldon version.
Old Aug 14, 2012 | 01:40 PM
cottoneg's Avatar
cottoneg
Has anyone compared the quality of the commercially available bars?
Any differences worth noting?
oldalaskaman
they are all the same except for price
Old Aug 14, 2012 | 09:56 PM
jb78L-82's Avatar
jb78L-82
I use speeddirects and this modification makes a big difference in the front end stiffness!! It is NOT for looks. All C3's should have a spreader bar.
To front add on bar
