AC work with heater core bypassed?
Old Aug 12, 2012 | 08:48 AM
Chris Cornett's Avatar
Chris Cornett
Cruising
Default AC work with heater core bypassed?
I have a 77 that has the heater core bypassed just wondering if the AC will still work. Dont want to tear the dash apart if I dont have to thanks.
Old Aug 12, 2012 | 09:11 AM
SH-60B's Avatar
SH-60B
Yes it'll still work.
Old Aug 12, 2012 | 09:22 AM
7T1vette's Avatar
7T1vette
There is no direct connection between the heater and the A/C system...other than they both feed air into the same plenum. As long as the heater-A/C system is working properly, you can use the A/C system exactly as intended, even though no heat is being introduced by the heater core.
Old Aug 12, 2012 | 10:07 AM
oldalaskaman's Avatar
oldalaskaman
if you're leaking hot water it will work better
Old Aug 12, 2012 | 10:43 AM
xkeots's Avatar
xkeots
It is actually 2 separate systems ran by the dash control
With core blocked or bypassed you won't get heat inside car ( except from motor and exhaust)
To AC work with heater core bypassed?
