TH 400 Won't Shift Under Heavy Load
Old Aug 13, 2012 | 10:47 PM
DESI6327's Avatar
DESI6327
Default TH 400 Won't Shift Under Heavy Load
My '68 Vette just came back from the shop for "other" repairs. Now, out of nowhere, the tranny won't shift when I put the accelerator to the floor. It's fine at normal speed, but once I "Get On " her....It revs to the red line, and HOLDS!!!
Mechanic says everything is fine...(Of course) Never happened before. If I put the metal down, it always took off, shifts...1,2,3 no problem..Now? Only at slow speeds
Anybody...Help!!! Bringing her back in tomorrow.
Thx,
Bob
Old Aug 13, 2012 | 11:18 PM
TimAT's Avatar
TimAT
I would suspect the vacuum modulator or the line to it first. Usually, when the vacuum is off it won't hardly shift at all anytime. But it's an easy place to start looking.
Old Aug 13, 2012 | 11:19 PM
c3dreamer03's Avatar
c3dreamer03
I'd start my investigation at the modulator valve. Other than that, good luck bud.
Old Aug 13, 2012 | 11:34 PM
TOM B1's Avatar
TOM B1
could be a couple of things but my first thought is the governor
or the gov screen is cloged.
I found this for you.
http://www.dragracingonline.com/tech...vi_9-bm-1.html
Old Aug 14, 2012 | 12:31 PM
7T1vette's Avatar
7T1vette
Does it have the same number of miles on the odometer as when you left it at the repair shop? If not, maybe the 'grunts' were out doing donuts in the back lot when the owner was out...
To TH 400 Won't Shift Under Heavy Load
