71 windshield wiper door problem
Old May 30, 2002 | 09:13 AM
SevenT1Shark's Avatar
SevenT1Shark
Default 71 windshield wiper door problem
When i start car , wiper door comes up and when i shut ignition off door does not go down. Wiper switch is off and override switch is off. What do i look for?
Old May 30, 2002 | 09:56 AM
mrvette's Avatar
mrvette
Default Re: 71 windshield wiper door problem (SevenT1Shark)
OK< you probably have a vacuum line off somewhere under the dash, that mans you have no vacuum to the controll relay, ever....so the spring inside the vacuum relay keeps the door open....keeping that sideof the canister motor under vacuum....
it's a controll issue, allmost bet on it....
gotta trace the lines, but take short cut and do the uncomfortable and check under dash first....flashlight helps...it's a pain in the butt...
GENE
Old May 30, 2002 | 12:35 PM
theandies's Avatar
theandies
Look at these posts this is your problem. http://forums.corvetteforum.com/zerothread?id=271473
http://forums.corvetteforum.com/zerothread?id=183547
Hope these help. This is the classic dirty wiper door selenoid symptom.
John
Old May 30, 2002 | 12:40 PM
mrvette's Avatar
mrvette
Default Re: 71 windshield wiper door problem (theandies)
Andies, you are correct, also....could well be that too, I"m trying to optimistic though....
GENE
To 71 windshield wiper door problem
