Manifold performance gain?
Old Aug 17, 2012 | 09:48 PM
jcloving's Avatar
jcloving
Default Manifold performance gain?
I was wondering if there is much performance gain to be had with a intake manifold switch on my stock 76 L-48. I was thinking an edelbrock performer intake under my stock q-jet.
I already have long tube headers, true duals and an x-pipe. I would be using the stock heads and cam.
From reading the edelbrock site it seems like there may only be a 5hp/5tq gain, which would not be noticeable or worth it.
Let me know your thoughts,
John
Old Aug 17, 2012 | 10:00 PM
Shark Racer's Avatar
Shark Racer
If the intake is coming off, it may be worthwhile, especially if you have one laying around. You can find them on ebay pretty cheap too.
The weight savings are worth more than the power difference.
Old Aug 17, 2012 | 10:28 PM
7t3shark's Avatar
7t3shark
Agree about the weight savings but w/o a cam and/or head change, performance gain will probably be marginal. Nothing wrong w/ the Q-jet tho.
Old Aug 17, 2012 | 11:05 PM
7T1vette's Avatar
7T1vette
If you are putting that intake on the stock block with stock heads and cam..... no.
Old Aug 17, 2012 | 11:25 PM
billla's Avatar
billla
St. Jude Donor '14
An engine, simplified, is an air pump. The more F/A mixture we can move in - and out - of the engine, the more power it will make.
Headers and exhaust are usually the best first improvement on a GEN I SBC because of the inherently poor exhaust flow - and they provide the foundation for everything else. An intake on it's own will add negligible power...but combined with headers/exhaust - even on a relatively mild engine - will show reasonable power gains.
Add a cam, and you're getting everything the heads are capable of delivering.
Old Aug 18, 2012 | 12:05 AM
cv67's Avatar
cv67
St. Jude Donor '05
without other mods no
Old Aug 18, 2012 | 08:09 AM
Jedi926's Avatar
Jedi926
This past Spring I replaced my stock 78 L48 intake with an Eddy performer intake. Next is the headers and exhaust, and I will be going to duals and no cat.
Old Aug 18, 2012 | 08:30 AM
jcloving's Avatar
jcloving
Thanks for the feedback
Old Aug 18, 2012 | 03:50 PM
7t3shark's Avatar
7t3shark
Without going to the 2.02 intake valve heads, a manifold is not much help.
Old Aug 18, 2012 | 07:29 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
had a buddy with a Jeep Comanche truck once that was working me over with his truck. I had an 80 model chevy truck with a 305 and he would take me by 20 plus truck lengths in the 1/4 mile.
I changed the rear from a 2.72 to a 3.42 and put a small RV cam in and he still beat me by around 6 or 8 truck lengths.
I than did nothing more than change the intake form a Weind to a performer and I beat him by 6 or 8 truck lengths.
The intake can make a pretty good improvement if that's where the restriction is.
Neal
Old Aug 18, 2012 | 11:28 PM
7t3shark's Avatar
7t3shark
I suspect if the manifold change was made first, he would have still had you by 6-8 lengths.
To Manifold performance gain?
