Suspension upgrades
Old Aug 18, 2012 | 04:54 AM
dgheinen's Avatar
dgheinen
Default Suspension upgrades
I'm looking at getting new coil over springs and shocks. I'd like to lower the ride of the car to reduce the gap over the wheels. I'm running the stock 15's now, but am going to 18's in the near future. What all do you guys recommend? 550 lb springs, and Bilstein Sport Shocks? If yall could post links, I'd greatly appreciate it. Thanks in advance!
-Damon
Old Aug 20, 2012 | 01:53 PM
MelWff's Avatar
MelWff
Exactly what coil over springs and shocks are you looking at?
Old Aug 21, 2012 | 03:44 AM
cottoneg's Avatar
cottoneg
First we have to know the intended use. Better street performance? Are you going to time trial the car? Race it? It will make a difference in what people recommend.
Old Aug 21, 2012 | 04:19 AM
dgheinen's Avatar
dgheinen
I definitely want better street performance, with the occasional track runs every once in a while. I was looking at
http://www.tirerack.com/suspension/s...8&autoModClar=
and maybe http://www.summitracing.com/parts/EIB-06002500550/
Old Aug 21, 2012 | 09:18 AM
oldalaskaman's Avatar
oldalaskaman
the tire rack pieces, wont fit your car, do some more research
Old Aug 21, 2012 | 09:46 AM
MelWff's Avatar
MelWff
Default Not Coil Over Shock
As pointed out by OldAlaskaMan above, what is in the picture will not fit your car and it even states below the picture it is an approximate, which in this case is not even close. Below is the same part number with the correct picture
http://www.summitracing.com/parts/BSN-24-184526/
Old Aug 21, 2012 | 09:51 AM
oldalaskaman
these will fit the front of your car and other venders carry variations
http://www.summitracing.com/search/B.../?autoview=SKU
Old Aug 21, 2012 | 05:40 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The more importance you place on handling and trackday performance, the more homework I'd suggest doing before spending much money. There's a bit more to it than simply changing tires, springs and shocks.
Old Aug 21, 2012 | 06:44 PM
johnt365's Avatar
johnt365
What is the gap now? I have a small block car that has the a/c removed and aluminum heads. The gap was huge in front and back. I just installed the 550# springs from wilcox and it dropped the front 1.5 in.
I changed the rear spring to a vb&p 360# spring and have koni shocks set on 5. To me, there is nothing harsh about the ride quality. I do have stock size tires. I have read that this is close to the gymkahana or fe7 upgrade option.
It feels much less bouncy and sits lower.
Old Aug 21, 2012 | 11:31 PM
68thumper's Avatar
68thumper
-Damon
I have this kit. Works good. The springs are 550lb. If you lower the car too much you will bottom out the shocks. I cut the lower shock mounts off the control arms and welded new tabs that were about half an inch longer and angled them down about 1 inch for additional shock travel. What a difference in ride quality.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1935
Old Aug 29, 2012 | 11:11 PM
Ray Y's Avatar
Ray Y
Here is the link to my build thread that is very similar to your request...Hope it helps & gives you motivation.
http://forums.corvetteforum.com/c3-t...-upgrades.html
Shortcut to the result...
To Suspension upgrades
