I am replacing my front wheel bearings on my '79, because I have no idea when they were last serviced. I completed the drivers side and now I am working on the passenger side and noticed the hub will spin with little force and continue spinning after I let go. The completed side spins, but as soon as I let go it stops. Did I do something wrong on the drivers side or should you be able to spin the hub 4 or 5 times with a single push?
Even if the bearings are preloaded correctly, the new wheel seal and grease will stop it from spinning after you let go of it.
I agree - If you adjusted them properly
While rotating the wheel, tighten spindle nut to 12-15 lbs. ft. torque.
Back off adjusting nut one flat and insert cotter key pin. If slot and pin hole do not line up, back off the adjusting nut 1/2 flat or less as required to insert cotter pin.
Bearing should have zero preload and .001" to .008" end movement when properly adjusted.
Once you tighten the bearing down, you need to back it off to the next spot where the cotter pin can be inserted. If you don't back the nut off "one flat", the bearing clearance will be too tight and the bearing will fail in short order.
I just finished the other side and they spin equally. I think the passenger side spun really easily due to worn bearings. I am replacing the calipers with Wilwood's during this process and when I took the passenger side caliper off one of the pistons was leaking which could have caused the bearing issue.
Also check your spindles when changing bearings. If the spindle is marred or "burned" where either bearing is, then the bearing was spinning and the spindle should be replaced, I have been told. Since the marred or "burned" part will just cause the new bearing to fail very quickly. Also if there is any rust or pitting on the spindle where the center section of the hub is, the part between the bearings, then that means one of the bearings let moisture in and if the spindle can not be polished out with Crocus cloth or other fine abrasive then the spindle also should be replaced at the same time you do your bearings.
Spindles were both in great shape with no rust or marring. I am hoping to get everything back together and drive it. I'll report back once I have driven it.
