dented frame
Old Aug 20, 2012 | 06:14 PM
Romasko's Avatar
Romasko
Cruising
Default dented frame
Hey Guys, i have a 1980. The frame has dents from someone trying to jack up the car in the wrong spot.
Any help on how to fix this?
Old Aug 20, 2012 | 07:07 PM
Cybernetic Medic's Avatar
Cybernetic Medic
The mods will probably move this to the C3 section. It will be helpful if you post pics so those familiar with C3 frames can better comment on repairs.
Good Luck, and welcome to the forum!
Old Aug 20, 2012 | 07:27 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
IBTM ...................
Old Aug 22, 2012 | 08:05 AM
Romasko's Avatar
Romasko
Cruising
Sill working on the pix thing, will download soon
Old Aug 22, 2012 | 10:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I assume you mean a dented front crossmember. There is a tool you can purchase to get some of the crossmember dents out. It's an expensive tool. Can you live with what you have?
If the frame is actually dented, you might have bigger issues.
Old Aug 22, 2012 | 03:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My frame is rock solid, I can't really jack up the front or back without the whole side coming up. That said the use of a jack with a small surface area that contacts the frame can put a small dent in it. I use pads on my jacks. If in fact that's where the OP's dents are.
Another one is jacking it up buy some part of the floor underside area instead of the frame, I have seen some brain surgeons dent different areas by doing that
Old Aug 26, 2012 | 11:11 AM
Romasko's Avatar
Romasko
Cruising
Got the pix in but they are in my gallery, sorry.
Check pix there. Thanks
To dented frame
