Rag Joint
Old Aug 20, 2012 | 06:25 PM
blu7t3's Avatar
blu7t3
2nd Gear
Default Rag Joint
I just set the body of my 73 back down on the frame with new poly body cushions....the problem is the rag joint for the steering doesn't line up...it's fine from left to right, but the the steering column is an inch higher than the steering box.....any suggestions ????
Old Aug 20, 2012 | 06:46 PM
C6DuffMan's Avatar
C6DuffMan
Are the column bolts tight? I could be wrong, but I thought there was some adjustment available on the firewall.
Old Aug 20, 2012 | 08:15 PM
redwingvette's Avatar
redwingvette
On the floor there are two bolts that can be loosened to allow the column to move up or down. Make sure your body mount bolts are tight before you re-tighten the column bolts because the mounts will compress some.
To Rag Joint
