tach problem and ?
Old Aug 20, 2012 | 11:37 PM
firstvett69's Avatar
firstvett69
Default tach problem and ?
72/ tach slow to react and seems to be off 1500 to 2000 rpm, at idle showing 500-550, earlier the same day at idle 800-850 normal, at 70 should be around 3500+ m22 and 4.10s. I have checked the dizzy wire under the point plate and grounds to the vacuum advance base screw seams to be OK, tight and corrosion free, could the tach filter be bad ? I would like to replace it first before possibly having to rip in to the dash and send out for repair, any suggestions and where can i find a tach filter ? and will any year tach filter do the same or be the same THANKS for any and all advise, the more the merrier, I like lots of opinions helps me and others learn more every day. .......Garry
Old Aug 21, 2012 | 08:23 AM
1986coupe's Avatar
1986coupe
Isn't the tach mechanical on a 1972?
Old Aug 21, 2012 | 08:35 AM
'75's Avatar
'75
Old Aug 21, 2012 | 10:21 AM
firstvett69
Default tach ???
OK, Did not want to get panties in an up roar its for a 1972 z28, OH that's a Chevy by the way LOLOL, My heart steal beats for that next 69 big block that I will have soon I'm looking for the right one. At the moment my problem is the Tach on the z28, please don't thump on me to hard, there is to much good info and wise wrenchers in the corvette world, THANKS for any and all help .......................Garry
Old Aug 22, 2012 | 12:12 AM
1986coupe's Avatar
1986coupe
Your 1972 Z28 engine was originally built right in my area, at the factory where the current Corvette engine is produced. St.Catharines Power Train.
Anyway, is you have an HEI system on that car then check the tach filter first. That is the cheapest place to start.
Old Aug 22, 2012 | 10:58 AM
firstvett69
The dizzy is stock, points and all, Im going to delete the filter and see what happens and go from there thanks for the info. Every little thing helps................. Garry
Old Aug 22, 2012 | 11:03 AM
Mike Ward's Avatar
Mike Ward
If you have a stock points distributor with mechanical tach drive there is no 'filter'.
Old Aug 22, 2012 | 12:49 PM
Shark Racer's Avatar
Shark Racer
Let's let him delete it and see what happens...
Old Aug 22, 2012 | 01:22 PM
'75's Avatar
'75
Firstvette69 is talking about a 72 Z28 with electric tach, not a vette. He's posted the same question on 3 different threads.
To tach problem and ?
