Spin Doctors
Old Aug 23, 2012 | 09:40 PM
silver79's Avatar
silver79
Default Spin Doctors
I have a 268EX comp cam in my 1979 corvette L-82 automatic. My brakes a very week, the pedal get very hard , when press. I had the vacuum system checked and they are telling me I am pulling about 10 " of vacuum the cam can be the cause, it isn't producing enough vacuum..... This cam has been in my Vette for at least 7 years, what do you guys think the problem is?
Old Aug 23, 2012 | 11:37 PM
Shark Racer's Avatar
Shark Racer
If it just started happening... the booster is going south. I'm assuming it didn't start happening 7 years ago.
Make sure, of course, that there aren't any other vacuum leaks in the system that could be disrupting the booster.
Old Aug 24, 2012 | 12:03 AM
George Ries's Avatar
George Ries
Default cam
i have run the same cam in my 76 and went to the next one bigger and my power brakes have had no problems its your booster
Old Aug 24, 2012 | 08:03 AM
silver79's Avatar
silver79
No it was fine 7 years ago, I will Chang the booster
Old Aug 24, 2012 | 10:25 AM
1yy07's Avatar
1yy07
Default booster repaier
send your booster to booster dewey 503-238-8882. time and $ well spent
Old Aug 24, 2012 | 01:49 PM
silver79's Avatar
silver79
The vucumm reading at the carb is between 5 and 10" my mecanic says that the engine is not producing enough vacuum....
I that vacuum normal?
Old Aug 24, 2012 | 03:13 PM
scottyp99's Avatar
scottyp99
If the brake booster has a leak, she bleeds off the vacuum, like a vacuum leak. Fix the leak, and the engine, she will produce more vacuum! C'est bon!!!
Keep the shiny side up!
Scott
Old Aug 24, 2012 | 07:49 PM
cgc's Avatar
cgc
Pull the vacuum line going to booster and plug it. Check vacuum reading again. If vacuum is up booster leaking. If vacuum is same well ???
To Spin Doctors
