Is it as simple as changing out the carb and the distributor?
Ive seen threads saying that if the prom dies, a new one can be bought from Hypertech but for the same price I could get a new distributor and I already have a good rebuilt Qjet.
Im thinking of upgrading to new heads, cam and dual exhausts and have heard the computer can get confused by a low vac signal ( easily addressed with a MAP sensor voltage adjuster circuit ). Also I like the idea of being able to dial in the timing rather than have the comp do it.
Yes, you are correct. Dist and Carb. A good dist can be bought for cheap. Set it all up right and an easy swap, did mine in less than an afternoon including setting the timing and carb all to Lar's specs and HAVE NOT HAD A SINGLE NEED SINCE TO TOUCH EITHER OF THEM. I also removed ALL of my smog crap and have headers and true duals. And for a point of reference, my mileage is as good or better than any 81 with the CCC. I have no regrets.
Thanks for that. Can I ask what distributor you went for?
Best bet is a stock GM HEI setup. They are cheap, very reliable and will do the job just fine. Might not be as fancy and pretty as Pertronics and the like, but unless your racing all out there is no reason to run something like that. That is unless you just like the look and spending the money.
More than happy to go with a stock unit. What would the GM part# be?
From: Las Vegas - Just stop perpetuating myths please.
That computer just contols the primaries mixture of your carb.
What this means is that when u go WOT the secondaries still control the mix.
Do u really want to do this? Computer controls carb from idle to cruise only - doesn't control timing at all.
cardo0
Sure it does. The ECU controls the timing just like a vacuum advance can does, that is why you need a new dist when you take it out. These 81 motors will never get a Qjet to open the secondaries all the way, it ain't gonna happen even at WOT unless they are beefed up, And since most of us spend very little time at WFO if any then the comp controls things most of the time.
Is it better to leave the harness installed from a value standpoint, assuming it gets sold one day?
All of the harness related to the computer in the engine compartment can be easily unlugged. There are connectors at the firewall. So your not "ripping" out anything, but merely removing them. I removed mine along with the smog crap and EGR crap. I will never put any of it back on, I can hand to someone if I sell it though.
Ok cool, I think of the resell angle and am probably too sensitive since I've had so many VWs with hacked wiring
Ok i looked that up.
'81 does have a computer controled dist where '78-'80 do not. But there is support out there with a just an EPROM chip upgrade for a performance tune. Though i never installed one in an '81 i did one for my '90 pickup - simple and cheap.
BTW a common complaint is the air valve and secondaries - need to be adjust correctly regardless electric Qjet or not.
cardo0
That Hypertech chip is a joke in the 81, it really does not do much. You get a better boost from a better initial timing setup and pipes and a rejet. The need to do al l the normal tuning and worry about the crappy dinosaur of a computer system is the reason I jerked mine. I have not touched anything since my initial tune with the new carb and dist. I jacked with that stupid computer stuff for a month after I got the car.
