I've had nightmares with poly bushing front and/or rear.
It has always been my though that taking a rubber part out of a car that already rides like a tank, and replacing it with poly only makes them ride harder. If you are going to road race the car then by all means I'd go poly. But for a daily driver rubber is best.
The SU01 series kits on our site in the forum special section are the USA made kits and everything is Moog except for the upper joint which is Federal Mogul. (the main reason is that the moog upper joint looks like a top hat) and it is the only kit I will let my shop install. http://willcoxcorvette.com/advanced_...rds=suspension
I checked out the site. I didn't see front and rear bushing kits. I need a complete bushing kit
That I can also replace trailing arm bushings. Thank you.
