Headlight Won't Go Down
Old Aug 25, 2012 | 07:13 PM
76Vett's Avatar
76Vett
Default Headlight Won't Go Down
Have a 76Vett, pulled into the garage a few days ago and, being in a hurry, I shut the car off before the headlights went down. I never thought anything about it but this evening I pulled it out for a drive and now the headlights won't go down. What do I have to do now?
Old Aug 25, 2012 | 07:19 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
check under the steering wheel first and make sure you didn't pull the over-ride switch down. (switch D below) This will lock them in the up position if it is pulled down.
If you didn't, then you probably have a line off the small hose side of the system. Translation, go to the relay and see if you have vacuum on the small hoses. (Check the small hose at point L in red below)
If you do have vacuum then you may have a part failure somewhere. If you don't go looking for the cause.
If you don't go to the over-ride again, L.. and pull off the hose H and see if you have vacuum there...
The default position on the headlamp relay is the make the lamps come open when there is a failure in the control side hose.
Willcox
Old Aug 25, 2012 | 07:24 PM
gcusmano74's Avatar
gcusmano74
It won''t go down? "If you have an erection that lasts more than four hours, see your doctor immediately."
Just joking. The headlight actuation system is designed to fail open, so that you can use your lights. You probably developed a vacuum leak somewhere. Put your detective hat on, and check it out, one thing at a time. If both sides failed at the same time, look at the common hoses and controls.
Good luck.
Old Aug 27, 2012 | 09:51 PM
76Vett's Avatar
76Vett
Thanks WILCOX - it was the over ride switch. I never knew what that was but I pushed it up, started the car and in seconds - the headlights went down.
Old Aug 27, 2012 | 10:41 PM
0Willcox Corvette
Former Vendor
Love the simple fix..
Old Aug 27, 2012 | 11:57 PM
scottyp99's Avatar
scottyp99
I love happy endings........just like my last massage!
Ohhhhhhhh.......inappropriate!
Keep the shiny side up!
Scott
Old Aug 28, 2012 | 10:27 AM
my 76 ray's Avatar
my 76 ray
Some mechanics would have charged you $300 to push up that switch.
Old Aug 28, 2012 | 12:08 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by my 76 ray
...Some mechanics would have charged you $300 to push up that switch...
Not in these parts.
$300 to get the car into the shop just to have someone look at it.
$300 for someone looking at it. Someone #1 might have to call upon the expertise of a Someone #2.
$300 for Someone #2 looking at it. Someone #3 is likely to show up at this point and offer free advice. Do not let them charge you for this.
$150 for Someone #2 to confer with Someone #1.
$150 for Someone #1 to actually offer a resolution to the problem.
$300 to resolve the problem.
To Headlight Won't Go Down
