LS 3 dowel pins
Old Aug 26, 2012 | 03:11 AM
DEEPSEA70's Avatar
DEEPSEA70
Default LS 3 dowel pins
Anyone put a LS3 with Quicktime bell and scatter shield in. My stock dowel pins seem a little short. Anyone find longer ones from any of the manufacturers that work. Mine are 1" 1/8. I think at least an 1" 3/8 would be better. 2010 Ls3 TKO-600 going into 70.
Old Aug 26, 2012 | 08:53 AM
Garys 68's Avatar
Garys 68
Are they driven in too far?
You're probably going to need offset ones to zero in the bellhousing, summit sells them, so at least you'll have another set to compare to.
Old Aug 27, 2012 | 01:52 AM
DEEPSEA70's Avatar
DEEPSEA70
Thanks,
I did notice Summit has 1.5 inch dowel pins. I'll try those, dial it in, and go from there. I think those will work out though. Then it's time to put it all in. Can't wait to start.
To LS 3 dowel pins
