Ignition analyzer tool
Old Aug 26, 2012 | 04:06 AM
Shark Racer's Avatar
Shark Racer
Default Ignition analyzer tool
Many years ago, a mech put some kind of scope on my distributor and it produced a graph which helped diagnose a dead/missing cylinder.
It had a chart for each of the cylinders and #6 was spiking or running low. Bam, burnt plug wire.
Does anyone know where I can find something like this?
Old Aug 26, 2012 | 06:34 AM
noonie's Avatar
noonie
Commonly referred to as Sun machines or just scopes.
Doubt if there are any around any modern shops. No need for them these days with modern cars.
Maybe an old shop in a smaller town.
If you just want to check for dead cylinders, you can use an IR temp gun on each exhaust.
Old Aug 26, 2012 | 08:13 AM
oldalaskaman's Avatar
oldalaskaman
they are still available , used
http://www.ebay.com/itm/Sun-Engine-A...515599&vxp=mtr
hope this helps
I'm remembering that they were good for cylinder balance and output of each individual cylinder, helped to identify alot of issues without taking things apart, except for the scope , the hand held testers of today do the same things, but the scope was an excellent tool that I miss.
Old Aug 26, 2012 | 11:09 AM
Learning_Curve's Avatar
Learning_Curve
That funtion is basically just an oscilloscope. You can search ebay for a used one.
Or you can spend some real money and get something like a Snap-on Vantage.
Old Aug 26, 2012 | 11:21 AM
billla's Avatar
billla
St. Jude Donor '14
An oscilloscope is great, and tells a lot about the actual voltage reaching the plug.
For simple firing/not firing/intermittent you can always just hook the inductive pickup of a timing light to each wire.
That Vantage looks amazing!
http://buy1.snapon.com/products/diag...0f&dir=catalog
Old Aug 26, 2012 | 11:25 AM
Garys 68's Avatar
Garys 68
I picked up one of these for $40 from Actron. Works great, I get a lot of use out of it.
Oh yeah, and much easier to carry on a boat than a big scope.
http://www.actron.com/media/usermanu...er_MNL_Eng.pdf
Old Aug 26, 2012 | 06:15 PM
Shark Racer
I'm thinking an occasional miss might show up as a dead cylinder as well... I picked up an IR gun. Guess I'll find out!
Old Aug 26, 2012 | 09:25 PM
Learning_Curve
If you don't have a IR gun, you can take a spray bottle full of water and spray it onto the exhaust manifold after the engine is warmed up. The water vaporize when it hits the manifold next to a cylinder that's firing, and won't if the cylinder is misfiring.
And for the occasional miss, I would be thinking ignition. Just get a spark tester, or make your own by cutting the ground strap off of a spark plug. The larger gap will force the coil to produce a higher voltage to jump across. If you just pull out a plug and see if it spark you're not really testing the system as it takes much less voltage to fire a plug when it's out of the cylinder compared to when it's operating under combustion chamber pressures.
Old Aug 26, 2012 | 09:30 PM
noonie's Avatar
noonie
hope this helps
I sold my Sun 1115 Analyser a year or so for a couple hundred bucks.
Cost $49,000 new.
Had gas analyzer in it too.
Totally unnecessary these days.
Same with the dist machine, just do it with hand tools now.
Old Aug 27, 2012 | 12:09 AM
Shark Racer
Any thoughts on the GTC TA100 / TA500 handheld devices for this purpose?
To Ignition analyzer tool
