Bleeding Brakes with Phoenix Systems
Old Aug 26, 2012 | 06:05 PM
Chris Cornett's Avatar
Chris Cornett
Cruising
Default Bleeding Brakes with Phoenix Systems
Hey guys anyone use the reverse flush method to bleed calipers on a C3 before? I replaced all calipers and rubber lines but I cant seem to get all the air out. Just wondering if anyone has done this with any luck Thanks
Old Aug 26, 2012 | 06:15 PM
oldalaskaman's Avatar
oldalaskaman
luv it , cuts down on air in the line comebacks, a real timesaver
Old Aug 26, 2012 | 07:08 PM
Chris Cornett
Cruising
Is there any tricks to it? I cant get the pedal to firm up.
Old Aug 26, 2012 | 07:24 PM
oldalaskaman
take the cap off the m/c, start at the r/r , push brake fluid till you have it overflowing the m/c, shut the bleeder, disconnect. go to l/r ,same procedure, always overflow the m/c, r/f same, l/f same. very messy. when finished with l/f , put cap back on m/c , flush with water. That takes all the air out of the system. if your issue is a pedal that will pump up , that will fix it, unless you need brake work , if your issue is a pedal that is the same all the time but soft, start looking for rubber lines that expand when brakes are applied. stating what year of C3 would help , they are all a bit different and there may be others who have fixed or need fixed the same issue.
Old Aug 26, 2012 | 08:54 PM
Chris Cornett
Cruising
Sorry its a 77 and I replaced all the rubber hoses and calipers with o ringed units from VBP.
Old Aug 26, 2012 | 09:12 PM
oldalaskaman
well...start bleeding
To Bleeding Brakes with Phoenix Systems
