Tackling 69 Brake issues
I've been having some serious brake issues on my 69. Of course, at one time they were great, and then started to develop the usual symptoms of C3 brakes. So far, I have relpaced all calipers to VBP stainless sleeved as well as new rubber lines at all 4 corners.
While bleeding the brakes, I get a strong stream coming from the bleeders, but of course it is full of air bubbles. I could bleed these things all day long and no matter what, it never improves. I took the car out over the weekend and it was pretty damn dangerous to drive. Pedal was very soft and car did not want to stop. I still have the stock master cylinder and it is a manual brake setup.
-Would my next step be purchasing a NEW (not rebuilt) master cylinder? I know this would not hurt, but will it cure my problems?
-How can I properly flush all that crap fluid out?
-Is there a better, more effective method to bleeding these brakes? Other than the old school pump and turn the screw technique.
-And are there any other methods or tips you can help me achieve adequate braking?
Thank you in advance
/Lee
Pics of the car...because we all like pics.
Just to clarify, the calipers are O-rings.
Also, if your braking system was drained of most brake fluid, you need to use the sequence of bleeding the brake components in the following order:
Master cylinder; front left caliper, front right caliper, rear left caliper (inner, then outer bleeder), rear right caliper (inner, then outer bleeder). And, as mentioned above, you need to be sure that the shuttle valve in the proportioning valve block is centered [and not shifted toward one side or the other]; then bleed each component slowly, so that P-valve doesn't get tripped during the bleeding process.
Finally, when you think it is 'good to go', button it up, take it for a nice drive...over some RR tracks, if possible..., then do a final bleed on each caliper to get any dislodged/trapped air out. The GM manual says to use a rubber mallet on each caliper as it is bled (to dislodge that trapped air); but I've found that a bit of driving does that job better than a mallet.
You can waste your time screwing around with bleeding your brakes the traditional way. Or you can purchase the Motive Brake Bleeder and be done in one hour tops. I've bled brakes in a ton of cars and when I became a C3 owner I never thought twice about it until I had to bleed the brakes. It beat me up pretty bad. Finally I caved and bought the Motive and my brakes are great first time every time. Just make sure the master cylinder is bled correctly before you start or you will just keep pushing air into your system. Also make sure your rotors are within spec for run-out. If the rotors have excessive run out they will cause the pistons in the caliper to cavitate the brake fluid and create air bubbles in the system while driving. Another interesting characteristic of the C3. Fixed calipers.
Good Luck.
Good Luck.
I was thinking of investing in one of these, but do not know much about them and think it would be a great tool especially if I can use it on my other vehicles.
http://corvette-parts.zip-corvette.c...ower%20Bleeder
Don't follow the instructions exactly. Do not fill the actual bleeder with brake fluid. It's messy. Just put brake fluid in your MC reservoirs and then clamp the motive MC adapter on top with a couple of large C clamps. Then pump it up and bleed the brakes. You will have to check the MC regularly to make sure you don't run out of fluid.
Good Luck.
Hook up the little hoses, fill the M/C up and push on the end with a screwdriver until there is no more air.
It helps to tilt the M/C up-down and left & right.
Make sure the end where the screwdriver goes in has the same size hole as the one you take off, some have a large hole and some have a small hole.
Good Luck.
Use about 15 lbs of pressure on the Motive Brake Bleeder and put in two quarts of new clean fluid. You won't use it all but it's cheap.
I start at the rear, left or right, inner, then outter. Go the other side and do the same, inner then outter. Go to the front, left or right. While the calipers are bleeding strike them repeatedly with moderate force using a rubber or leather hammer to dislodge any air bubbles. Let each bleeder run for 30-60 seconds after you see the last bubble and you have clean fluid coming out.
with brando too. Just use the bleeder as an air pump- way less messy in case the reservoir top leaks (mine did) and no hassle with washing the bleeder out after you're done.
I just changed my passenger side rear caliper, I have been trying to get some fluid just to come out of the lines & nothing, dribbles. I have replaced the MC about 3 months ago& changed the fluid, Right now I have some wheels that wouldnt turn, feels like the brake is engaged , some that will just spin like nothing . I an thinking that it is the Porportion valve, should I change it? Is there a test?
Thanks Mark
