From: Who says "Nothing is impossible" ? I've been doing nothing for years.
VB Spreader Bar
This has been bothering me for some time now. I put in the spreader bar and noticed that it really only spreads the forward part of the upper A Arm. The thin piece of metal isn't going to do anything but maybe help it from coming off.
Does anyone agree, there should be a solid piece of angle iron welded onto the thin piece of metal up to just below where you attach the heim joint ?
I borrowed these pics from Eddie 70 hope he doesn't mind, to lazy to take my own and they came up in a Google search from 2003
The link is in double shear and it's pressing directly on the upper control arm so I guess it will keep the frame from moving...
I don't know if you'll ever feel any difference before the street tires loose grip. That why I never purchased one. Let us know if you can feel any difference.
if you mean a gusset from the base to the upright on the engine side, a long triangle from the other bolt hole to the upright. it would give the bar more stiffness and carry it the length , instead of being concentrated over that one leg of the control arm, yes. as previously stated , you may not need it
I have 17" C4 rims on my '72 vette, 255/50/17 in front.....and I can assure of one thing, you WILL feel the difference, immediately on the stock VBP configuration shown above photos.....
same as I have.....
but it helps to have electric fans for MANY reasons, not just the bar.....
same as I have.....
CASE CLOSED!!!@@#!
I'm running 17" C5 wheels and just installed spreader bar. Can't wait to "feel" the difference once I get back on the road.
I have solid motor mounts so I don't really notice it to much, I suppose the steering feels a little more responsive but I also did a grease job filled all the grease boots at the same time so.......
Yes I am a good engine builder but lousy fabricator / welder, a triangular gusset is what I meant...I think, and if I welded it in it would fall out over the first bump and I own a mig welder too, just never had the time to practice
I am taking it out tomorrow because ever since I installed in I am getting a bit of a vibration when I floor it above 3500RPM, I wonder if the solid motor mounts are fighting with the spreader bar for whose boss up there.
Originally Posted by redvetracr
move the heim to the center and it should spread the load equally...
Yes I was thinking about doing just that but would like support ( gussets ? ) on each side the metal is just too thin, but like I said above I gotta pay someone to it, the last thing I welded for my brother broke when he dropped it on the floor
You will feel the difference, I actually have had the spreader bar for some time now I took it out when I went to solid motor mounts, so it sat there looking at me and I decided since I bought it I might as well put it back in
From what I understood the best performance from this piece is with it directly between the shocks. Too far ahead of them (forward) still allows some frame flex. I use this bar and have mine set right between the shocks. Nice and stiff and stable.
I mounted mine (from VB&P) in the middle using bolts and welding. There is only about the width of a metal ruler between the bar and the water pump snout but I have not seen any evidence of rubbing.
[IMG][/IMG]
[IMG][/IMG]
I would like to say that the bar has helped, but I have hard compound tires on 15 inch wheels and so I can't say for sure yet. I can say that the frame under the engine was slightly deformed and that is what lead me to get the bar in the first place.
That's why I fabbed my own spreader bar mounts. The commercially made ones are one-size-fits-all design. I made mine for the best fit in MY engine compartment. It is not exactly in line with the shock studs as my water pump pully is aluminum and not as svelte as that steel one in your pic. But it is hell for stout and did make an improvement in frame flex.
BTW, I never once regretted learning how to stick, mig or tig weld.
I always felt better just knowing that the frame isn't flexing as much as it did before I installed it. I was happy to see that I didn't have the stress cracks that we have seen posted in the past of street driven C3s.
I learned how to stick weld in 1970, ordinary arc welder. Like I said I have a good Lincoln mig welder just sitting there, never had the time to actually practice and get into fabricating, well I can do some fabricating as long as it doesn't involve welding. I am still relatively young so you never know.....
Hey Mike how's it going, the big bore short stroke is still smokin' ?
