parking brake- 1978
Old Sep 4, 2012 | 11:22 PM
RedZR's Avatar
RedZR
Default parking brake- 1978
The parking brake on my 78 does not really "grab" (keep the car from moving) unless its pulled to the final click- all the way up.
I would like to adjust it so it grabs a little earlier. Can I adjust it a little at the equalizer rather than have to go back to the e-brake pads themselves inside each rotor?
Thanks,
Dan
Old Sep 4, 2012 | 11:31 PM
junkman123's Avatar
junkman123
hope this helps http://willcoxcorvette.com/repairand...lp.php?hID=141
Old Sep 5, 2012 | 07:28 AM
johnt365's Avatar
johnt365
How do you measure a 10 -12 lb finger pull on the handle?
Old Sep 5, 2012 | 11:25 AM
junkman123's Avatar
junkman123
one of those cheap fish weighing scales form walmart would work
Old Sep 5, 2012 | 11:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pull it. It should be somewhat easy to set the brake using only your right arm.
Setting the brake should not require two people trying to budge the handle back.
To parking brake- 1978
