Bellhousing
Old Sep 5, 2012 | 11:29 AM
Stingray-Jer's Avatar
Stingray-Jer
Default Bellhousing
I need to replace the bell-housing on my 1968. This was originally a 427, but now has a 454. It is a Muncie 4 speed.
The shop discovered a couple of cracks while taking the clutch out. I am replacing the clutch and will probably be going with a center force dual friction clutch. Looks like the flywheel has some hot spots as well.
I'm not doing this myself. I wish I had the knowledge and ability. I am ordering the parts myself and want to make sure I get the correct bell-housing. I wasn't sure if it matter that the engine is now a 1974 Chevy 454 built to 468.
Thanks guys
Old Sep 5, 2012 | 11:50 AM
MelWff's Avatar
MelWff
66 to 74 bigblock should all be the same, did you look at the listings at vendor sites?
Old Sep 5, 2012 | 12:28 PM
Stingray-Jer
I have nit looked yet. I'm not that familiar with which vendor to check. I checked Ebay.
Old Sep 5, 2012 | 01:39 PM
MelWff's Avatar
MelWff
here is an example
http://www.ecklerscorvette.com/corve...1966-1981.html
Old Sep 5, 2012 | 05:15 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Not sure about this - the SHP big blocks, which used the smaller 153 tooth light weight flywheel and L88 clutch, MAY have used the smaller bell housing used for most of the mid years. If so, the larger 168 tooth flywheel with 11" clutch won't fit.
YMMV
Old Sep 5, 2012 | 11:39 PM
fix69vette's Avatar
fix69vette
Get a Lakewood bellhousing!
Old Sep 6, 2012 | 12:23 AM
Stingray-Jer
Any recommendations on a flywheel??
Old Sep 6, 2012 | 11:18 AM
birdsmith's Avatar
birdsmith
Aluminum can be very easily welded...
Old Sep 6, 2012 | 01:04 PM
cottoneg's Avatar
cottoneg
One day I was sitting at a light and I heard a crack. I had no idea what it was.
The next day I found one of the small bolts that holds the pressure plate to the flywheel had come loose and at idle, cracked a hole through my bell-housing. Now imagine a one pound piece of flywheel at 6,000 RPM.
You may want to consider a scatter shield (two piece)
Old Sep 6, 2012 | 03:54 PM
Stingray-Jer
Do they still make 2 piece scatter shields??
Old Sep 6, 2012 | 04:58 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Who's gonn'a see a weld scar on a bellhousing. Just a simple bead/structural weld and sounds like fun to borrow/rent a 220V Lincoln stick welder. Gouge/grind out the crank on one side. Get some alum stick rod, set the Lincoln machine on AC current & setting for that rod and have some fun for cheap. Much cheaper than new bellhousing.
BTW the small block bell housing bolts up too but like was said u need the correct starter bolt pattern. Plenty of those old muncie bellhousings out there used - heck i got at least one spare without trying/looking - check craiglist. Alot of transmission sellers will part out a bellhousing for pocket change.
Hope this helps,
cardo0
Old Sep 6, 2012 | 06:10 PM
Stingray-Jer
Hope this helps,
cardo0
Thanks Cardo0
Old Sep 7, 2012 | 12:14 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
468 BBC?,..I'd use this opportunity to upgrade to a scattershield. Yes, it's 2x the money, but in the end, it's very inexpensive insurance against loss of limb,..or worse, the loss of your passenger's limb(s).
FWIW
Old Sep 7, 2012 | 12:34 AM
Dirk76's Avatar
Dirk76
any good links to some scattershields
Old Sep 7, 2012 | 11:09 AM
lvmyvt76's Avatar
lvmyvt76
summitt speed parts? any parts shop that sells speed parts will be able to get one, and may have it in stock.
Old Sep 7, 2012 | 11:29 AM
Stingray-Jer
FWIW
Thanks Dark blue
Old Dec 6, 2012 | 01:13 AM
bigbarnman's Avatar
bigbarnman
1st Gear
Default Lakewood bellhousing
Hi Stingray Jer, I am restoring a 68 L88 now. It came to me with an explosion-proof Lakewood bellhousing. I will gladly trade it for the correct bellhousing for my car. Mine was also Corvette bronze when born. I have a very early Vin. Car was built 2nd week of Sept, 1967. Ken
To Bellhousing
Old Dec 6, 2012 | 01:25 AM
SuperBuickGuy's Avatar
SuperBuickGuy
yes.... and a steel flywheel, billet if your wallet can afford it.
That's a 12 - 20 lb piece of steel that's turning towards your ankles - so if it lets go (and they do) without a shield it will take whatever is in the way off (ask Don Garlits)
http://www.youtube.com/watch?v=hJtJUVyEyYY
and to answer your question... all SBC and BBC have the same bolt pattern, and while there are odd-ball transmission mounting bolt patterns, the block pattern is the same.
That said, there are some bellhousings that won't fit over an 11" clutch - but they're even a bit hard to find anymore.
Old Dec 6, 2012 | 08:31 PM
Stingray-Jer
I went with the Quick Time SFI bell-housing.
http://www.summitracing.com/parts/QTI-RM-6022
I also went with the a new Center Force Clutch and this Flywheel.
http://www.summitracing.com/parts/ctf-700140
Ken,
Thanks for the offer to trade.
I do not know if this is the original bell-housing. Would it be stamped with a number that I can verify. I had not noticed if it had the VIN on it or not.
I will be happy to check for you. I know it is NOM, but it is a BB 68. I am happy to check it out for you. It is cracked and will need a welding. I can get you photos if you need.
Old Dec 6, 2012 | 10:05 PM
Ironcross's Avatar
Ironcross
easiest solution is to weld your old housing like some others suggestion and you know that one fits......
