Oil pan / pump clearance issues
Old Sep 5, 2012 | 03:53 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Oil pan / pump clearance issues
Has anyone experienced any problem with clearance issues when using a Melling M-77 stock replacement oil pump / stock pickup screen and a big block factory high performance oil pan? Specifically, the baffling in the pan won't allow the pan to fit over the pump. Hate to modify the baffling in a perfect oil pan.
Old Sep 5, 2012 | 04:24 PM
MelWff's Avatar
MelWff
can you provide the part number of the pan?
Old Sep 5, 2012 | 05:57 PM
Dr L-88's Avatar
Dr L-88
Stock 67 427-435 original pan, 6 quart capacity with trap door.
Pickup screen is original GM..................
Old Sep 5, 2012 | 09:17 PM
Dr L-88's Avatar
Dr L-88
Just now bolted on my NOS L-88 pump (GM part #3964259) and the stock 427 - 435 pan clears perfectly. Not sure what is different about the Melling M-77 pump, but it won't work with the stock pan. Now I have to find a pump that will work with the pan................I'm saving the NOS L-88 pump for a "special" project.
Old Sep 5, 2012 | 11:02 PM
7T1vette's Avatar
7T1vette
Is the NOS "L-88" pump any different than the 'usual and customary' GM V8 pump? Is it higher flow or higher pressure than the stock unit? If only higher pressure, install a different regulator spring in a stock pump.
Old Sep 6, 2012 | 12:04 AM
noonie's Avatar
noonie
You are probably using a long pickup and the vette pan requires a short one.
Old Sep 6, 2012 | 03:17 AM
Dr L-88's Avatar
Dr L-88
No sir......................stock pickup............
Same post in C2 section got a response from babbah that he had to mill out some of the baffling in the pan.
To Oil pan / pump clearance issues
