fuse block conversion
Old Sep 6, 2012 | 11:52 PM
Chevypwr's Avatar
Chevypwr
Default fuse block conversion
I really would like to make it easier to change fuses. Is there a replacement fuse block to convert from the original AGC glass fuses for the newer ATC type? Thanks.
Old Sep 7, 2012 | 01:16 AM
oldalaskaman's Avatar
oldalaskaman
I believe 'painless' sells a conversion, a bit spendy though
Old Sep 7, 2012 | 01:34 AM
Chevypwr's Avatar
Chevypwr
You're right about the $$. I was hoping for a direct replacement. I don't know what the first year was they started using ATC fuses. Could this be used? I might be able to pick this up at a salvage yard. Can the original stock AGC fuse block be turned around and put on the engine compartment side of the firewall where someone could actually get at it without taking the dash out?
Old Sep 7, 2012 | 01:44 AM
oldalaskaman
I think you could put it there, would need to be waterproofed, I saw a thread on here where a member converted to a later year box but havent found it yet.
this member did it a bit different
http://forums.corvetteforum.com/c3-t...box+conversion
Old Sep 7, 2012 | 01:55 AM
Chevypwr's Avatar
Chevypwr
I found a 84 fuse block on ebay for $35. Am I looking at a major wiring headache?
I'll figure out how to keep it dry. I can make an enclosure if I get that far.
** I checked out the thread. He moved it behind the pass seat. That sounds like a major job. I was hoping for an easier solution.
Old Sep 7, 2012 | 04:45 AM
oldalaskaman
a lot depends on your skills, the biggest issue would be getting the wire bundle from the back of the current one , thru the fire wall and then correctly hooked up, time , a wire diagram, a test light, and patience
Old Sep 7, 2012 | 02:04 PM
7T1vette's Avatar
7T1vette
How often do you need to change fuses??? And glass fuses are still readily available at car parts stores or Radio Shack. I don't understand why you would go to the expense and trouble of changing fuse block/wiring just to have "modern" fuses?
If you can't personally change them when you need to, ask a neighbor or take it to a garage.
Old Sep 7, 2012 | 05:58 PM
lvmyvt76's Avatar
lvmyvt76
I have not had to change fuses for many years, why are you, having problems? I think you are asking for more problems in changing anything.
Old Sep 7, 2012 | 08:45 PM
Chevypwr's Avatar
Chevypwr
Is there a 90 degree fuse puller available? I gutted the interior last year and haven't got the dash lights to work yet. I was thinking that maybe it was a fuse. I've tried to pry a fuse out with a screwdriver and broke the glass. Also my new stereo has a clock. I wanted to stick a wire between the hot side of a fuse and the clip for constant voltage. How do I get constant voltage that is not turned off with the ignition? I'm inexperienced with electrical stuff.
Old Sep 7, 2012 | 09:18 PM
74modified's Avatar
74modified
You could get a tap like this at most parts stores. http://www.amazon.com/Wirthco-30200-.../dp/B000CQDRSE
Or there may be a constant power post in you fuse box. Either way, have a fuse in the line.
Old Sep 8, 2012 | 01:15 AM
Chevypwr's Avatar
Chevypwr
Those taps look great and solve my problem. I can see that there are no practical retro-fit fuse blocks available. Moving/changing the original is too big a headache and not necessary because fuses rarely blow. These taps let me expand the capacity in the block. Much better than jamming the wire between the fuse and clip. So simple I can't believe I didn't know about these.
Great input guys, Thanks
To fuse block conversion
