tranny lines
Old Sep 8, 2012 | 12:05 AM
jones4321's Avatar
jones4321
1st Gear
Default tranny lines
I have a 75 corvette 400 tranny 350 engine. My question is how the transmission lines hook up. Is it bottom hole on tranny to botton hole on radiator and top hole on tranny to top hole on rad or how exactly do they run. pictures will be helpful. Thanks this is my fist time
Old Sep 8, 2012 | 09:15 AM
Mooser's Avatar
Mooser
Pretty sure the lower trans is the lower rad but you can check, the end of the metal pipe kicks up at the rad for the upper connection
HIH
Mooser
Old Sep 8, 2012 | 09:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Sep 8, 2012 | 11:23 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Trans fluid goes out the lower port on the transmission and returns into the upper port of the trans.
To tranny lines
