overheating problem
Old Sep 8, 2012 | 09:51 PM
azguy's Avatar
azguy
Default overheating problem
I have a 79 with a rebuilt 350. less than 100 miles on the rebuild, new dewitts radiator, electric fan set to come on at 200 and 180 deg thermostat but the temp in the car just keeps climbing. it shot up before I installed the fan shroud but the fan shroud will keep the rnning temp around 220 or a little more when going between 60-70 on the freeway but if I go 75-80 it starts creeping toward red again. I can't figure out why it keeps going higher. does anyone have suggestions on what I can check? no leaks in coolant or anything like that. I have the break in oil still in it, if that could have something to do with it.
Old Sep 8, 2012 | 10:01 PM
78pace's Avatar
78pace
Do a search...there was just a post about over heating. Lars jumped in and talked about timing and over heating......
Old Sep 9, 2012 | 02:29 AM
bludorbronc's Avatar
bludorbronc
check your clutch on the fan. they wear out and dont draw like they should. the one i like to use is for an rv, it is extra tight and draws a lot of air.
Old Sep 9, 2012 | 03:57 AM
oldalaskaman's Avatar
oldalaskaman
if its creeping at speed, you're not getting air to it, check your front air dam and radiator sealing?
Old Sep 9, 2012 | 06:25 AM
74modified's Avatar
74modified
All of the above plus coolant mix, air out of the system, and pressure cap working correctly.
Old Sep 9, 2012 | 06:39 AM
azguy's Avatar
azguy
I bought 50/50 mix cooling and I think the air is out of the syste, is there a way to check? pressure cap is brand new as well but I will double check. I will see if I can find the timing thread, thank you everyone.
Old Sep 9, 2012 | 09:31 AM
Factor's Avatar
Factor
Second the clutch fan...and air dam
I would do a 160 tstat, which should run the engine at 180-185 (read somewhere this was optimal running temp)...
are you sure the clutch fan is coming on properly and not disengaging?
I had this problem and the fan was disengaging...found out by keeping on...with no issue and tweaked from there...
Old Sep 9, 2012 | 11:20 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
I think he has electric fans.
Old Sep 9, 2012 | 11:21 AM
AGVI's Avatar
AGVI
Did you try burping the rad?
Old Sep 9, 2012 | 12:19 PM
garygnu's Avatar
garygnu
summit sells a thermostat housing with a radiator cap on it,it cost $100 but it makes bleeding the coolant system easier.
Old Sep 9, 2012 | 12:20 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I need to know exactly what you have before I make any suggestions...
You said you have electric fans but then you said you installed the shroud which would be impossible with dual Spals. So, what kind of fan are you using? Pusher or puller? Single or dual? Do you still have a clutch and engine driven fan? Most important, have you checked the gauge reading with an IR gun? If your sending unit has been replaced during the rebuild there is a good chance it's telling you a 20-30 degree lie.
Old Sep 9, 2012 | 05:03 PM
7T1vette's Avatar
7T1vette
Is the lower radiator hose collapsing at speed (with elevated rpm)?
Old Sep 9, 2012 | 09:54 PM
azguy's Avatar
azguy
I do have electric fans. Not the dual fans dewitts sells with their radiators unfortunately. I have a single puller 16" high flowing fan from summit. It is running right. I checked. I'm not sure how to burp the radiator but I didn't install the engine either. It does have a new sending unit. Where do I check the temp with an ir gun? The temp will not stop at 220-230. It just keeps creeping toward the red. If it stopped I wouldn't be as worried. I couldn't find the thread that discussed timing, can anyone post a link for.me?
Old Sep 10, 2012 | 09:26 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You can shoot the IR gun at several areas to get a average. The thermostat housing and the upper inlet connection to the radiator. New motors will run a little bit hot until they break in and I wouldn't cruise high speeds until at least 500 miles. Just to eliminate it as a possible problem, I would put the thermostat out to see if that is working correctly. Do check that lower hose for possible collapse.
Old Sep 10, 2012 | 03:08 PM
Factor's Avatar
Factor
my overlook..."clutch fan"...I read it earlier and was spouting ideas off my head.
either way it led to more info...
Second the IR gun...I had a new sending unit not send correctly...found out it with the IR gun...so switched out the new one with another new one and it worked...parts guys said this sometimes happens....>FYI...
Old Sep 10, 2012 | 03:41 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you tested the temp sending unit?
Old Sep 11, 2012 | 01:42 PM
azguy's Avatar
azguy
No but it is brand new and it worked when I tested it in the other car. If I got a new gauge would it help it read right?
To overheating problem
Old Sep 11, 2012 | 06:43 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
If you check the temperature with an IR gun you can verify the sending unit and gauge reading all at once. If the gauge is saying 220 and the IR gun says 190, then you know something is wrong.
Old Sep 11, 2012 | 11:06 PM
azguy's Avatar
azguy
The fans come on at 200 like I set them so I the no its right but I will try the ir gun this weekend to be sure. It also keeps running sometimes when I try to shut it down. Sometimes just for a second tonight it lasted for 2 or 3. Is that a timing issue that could be contributing or something completely unrelated?
Old Sep 12, 2012 | 01:13 AM
oldalaskaman
where did you attach the power for your fans to?
