Engine Pinging
Old Sep 9, 2012 | 04:06 PM
Steve Elliott's Avatar
Steve Elliott
4th Gear
Default Engine Pinging
Hey Guys,
My 72 big block has suddenly started pinging on acceleration, I use the best fuel available from the pump but wondering if I should be using an
fuel additive as well?
Sorry if this has been asked before....
Steve
Old Sep 9, 2012 | 04:14 PM
George Ries's Avatar
George Ries
if it just started im guessing the the timing is set so maybe you should try getting gas at another station 93 or better
Old Sep 9, 2012 | 04:48 PM
694speed350's Avatar
694speed350
Originally Posted by Steve Elliott
Hey Guys,
Steve
If you are running 93 and it pings you might have gotten a bad tank of fuel. as far as a fuel additive they don't work. if after another tank it still pings check timing and you may have to retard it a couple of degrees.
Old Sep 9, 2012 | 04:52 PM
7T1vette's Avatar
7T1vette
If it's pinging, just check the timing. Timing can shift/drift with age of parts, etc. depending on what type of ignition system you are using. It's easy to check; that way you'll know if it's your adjustment or the gas.
Old Sep 9, 2012 | 07:04 PM
BOOSTED-SS-ELKY's Avatar
BOOSTED-SS-ELKY
You may check the timing and discover that its set properly and the gas you're running just ain't cutting it anymore. Gas is going to hell.
You have some options, octane booster (Yes, it does work, don't buy garbage) or take a couple degrees of timing out of it. It's going to be cheaper to take some timing out and you probably won't notice much of a difference.
Old Sep 9, 2012 | 07:09 PM
MelWff's Avatar
MelWff
Start with removing the distributor cap and rotor and check if your mechanical advance weights and springs are stuck in the fully advanced position. If they are stuck clean all the components. Then check your dwell angle and initial timing.
Old Sep 9, 2012 | 08:03 PM
my 76 ray's Avatar
my 76 ray
It might be that the points have gone out of adjustment which affects the timing. Check/reset the dwell before you do anything.
Old Sep 9, 2012 | 08:24 PM
Steve Elliott
4th Gear
Default Thank you guys
Its back to my mechanic this week...I appreciate the help!
To Engine Pinging
