Manual Brakes 1970
Thanks guys.
Kind of goes with "Let's do the cheap stuff first"
Most leakages will be on the inside of the wheel and you will see brake fluid splatter/dripping on the sidewalls of the wheel. But, it could also be found on the caliper, itself, or from a defective seal on a caliper piston.
Usually a "pull" condition during braking is due to a rotor that is 'grabbing' (due to pad wearout or fluid getting on the rotor) or 'slipping' (mechanical caliper/piston problem or fluid blockage in line/hose). A good visual inspection can often identify what may be happening with your braking system.
I had a problem similar with my car and found that it was the lip seals in the calipers. They would draw air into the system, I would bleed the brakes and have a great pedal the head out for a drive and by the time I would get back the pedal had just about gone to the floor. Replace the lip seal with "O" ring type calipers and have not had a problem since.
Also a good idea to replace the rubber lines while your at it.
Peace
Frank
I went with the stainless steel lines and converted to O-ringed pistons when redoing my 1970's manual brakes. My pedal feel is awesome and there is only maybe 1-2 inches of travel before the pads grab. If you go with the O-ring pistons check and make sure your calipers have the stainless steel sleeves.
leaky calipers with wet pads or rotors ( rebuild with o-ring kits)
also check for ballooning rubber lines ( replace them both) .
wheel bearings adjusted correctly on front?
suspension bushings/ball joints totally shot? ( alot less likely but possible)
all of the above can cause pressure differential or a different coefficient of friction at each caliper and cause your car to veer left or right upon braking.
The origional style caliper seals had very little tolerance for rotor runout, like 0.002" max. The Oring type caliper seals will tolerate a bit more runout without problems..
Firstly, most of the issues raised by you guys were correct and contributed to solving the problem. Many thanks. I removed the front left calliper and completely dismantled it and found it contained water!!! (probably drawn in from the worn seals) and likewise for the remaining calipers. I also did the same for the master cylinder. I noticed the master cylinder had corrosion on the walls and the seals were shot. Immediately ordered a new MC and a complete seal kit for the calipers. After overhaul and reassembly I noticed I could not bleed the rear brakes! (front were fine) I blew air (about 10 psi) up the lines to make sure the lines weren't blocked and they were fine. So I ordered a new proportioning valve and installed it, bled the brakes and now the ol girl stops like new. Next time it's stainless steel sleeves and pistons as well. Hope this helps anyone with C3 brake issues. Thanks AR.
