LS1... would this work??
Old Jun 1, 2002 | 07:31 PM
jerryjfunk's Avatar
jerryjfunk
Default LS1... would this work??
Is it possible to use LS1 aluminum heads on a mid 70's small block?
Thanks,
Jerry
Old Jun 1, 2002 | 07:40 PM
rainman69's Avatar
rainman69
Default Re: LS1... would this work?? (jerryjfunk)
Don't think so. Different cooling...reverse flow, if I remember right. Course, I could just be dumb. :cheers:
Old Jun 1, 2002 | 08:47 PM
GROSSPOLLUTER60's Avatar
GROSSPOLLUTER60
Default Re: LS1... would this work?? (rainman69)
Totally different generation of small block. No parts are interchangable. :confused:
Old Jun 2, 2002 | 12:44 AM
Tom73's Avatar
Tom73
Default Re: LS1... would this work?? (GROSSPOLLUTER60)
You can consider the "Classic" small block as Gen 1. Then you have Gen 2, the LT1 of '92-'96. Only major part interchangable with Gen 1 was the crankshaft. Then the Gen 3, the LS1. No marjor parts interchangable with Gen 1 or Gen 2. Totaly different designs.
tom...
Old Jun 2, 2002 | 02:25 AM
70 LS1's Avatar
70 LS1
Default Re: LS1... would this work?? (Tom73)
I have to reply just because I saw LS1. The answer is no way, no how.
Old Jun 2, 2002 | 01:15 PM
jerryjfunk's Avatar
jerryjfunk
Default Re: LS1... would this work?? (70 LS1)
That's what I thought, thanks for the replies!
What do a good set of LS1 heads go for, anyway?
Thanks,
Jerry
Old Jun 2, 2002 | 01:37 PM
70 LS1's Avatar
70 LS1
It depends on if they are stock or ported. huge price difference. Anywhere from a couple hundred to over a thousand. What do you have?
[Modified by 70 LS1, 9:38 AM 6/2/2002]
To LS1... would this work??
