Sensitive horn - easy fix
Old Sep 15, 2012 | 11:55 AM
bluthundr's Avatar
bluthundr
Default Sensitive horn - easy fix
My horn in my 76 never worked from when I bought it. I recently got all the missing pieces I need and reassembled it but found that the horn button was super sensitive. I also found this was a pretty common problem and wanted to share an easy fix.
The actual horn contact is just the two pieces of metal shown here, separated by an insulator. The leg that comes off the bottom goes through the column, down the T&T spring in my case, through a few other contacts, and down to the horn relay. That leg should always be touching it's contact. When you press on the horn cap, it grounds this contact through the mounting screws and closes the relay.
Adding shims behind this piece only moves the horn cap in and out, it doesn't really change the contact.
If the plastic rivets holding this mechanism together are broken or missing, this is a good fix too. Mine were there but were not holding well. The first step is to remove the rivets and disassemble the horn contact.
Here you can see the insulator that keeps the two sections apart.
Next, go to your local hardware store and buy some 10x24x1/2 NYLON screws, washers, and nuts.
Reassemble your horn contact bring the screws in from the back. Start with one extra set of nylon washers in between the contacts. Since it is bolted together now, you can take it apart and add another set if you need it.
Fasten it back together with nylon nuts, ensuring the nuts are situated with the flats and not points out so that they don't interfere with the horn cap, and that's it.
You can see the area between the contacts is now doubled.
After putting the cap back on, it now takes a "normal" amount of pressure to blow the horn. Hitting or rattling the steering wheel would not make it blow.
Old Feb 21, 2015 | 02:54 AM
76_vette_girl's Avatar
76_vette_girl
I can't wait to try this fix! I can barely touch mine and it goes off and it wants to stick on if I slam it when someone does something dumb
Old Feb 21, 2015 | 10:24 AM
terry82's Avatar
terry82
I will have to do this fix come spring .I live close to you but its to cold to go out there.
Old Feb 21, 2015 | 01:14 PM
76_vette_girl
Luckily I'm able to do some work on her in my garage. I'm just not excited to get back into the steering wheel since the horn spring and contact is very fiddly. I have run into parts quality issues from major parts suppliers (won't name names).
I got a steering coupler which was a complete 180 degree reverse of my original. Fortunately, I was able to figure a fix.
Old Feb 21, 2015 | 08:49 PM
76_vette_girl
Fix is complete.. works great and is adjustable.. Absolute genius!
Old Mar 20, 2015 | 09:38 AM
C376FL's Avatar
C376FL
Hi blu,
When I bought my 76 about 2.5 years ago I found the horn parts in the passenger side map pocket. I was in no hurry to fix it because there were to many other things that needed to be fixed
first. I started to do the repair you showed in your post, and it worked out nice. The only parts missing where the three long screws. Do you know the size, and length of those screws?
Thanks for your help.
Larry
Old Mar 20, 2015 | 10:46 AM
Kris Tunetso's Avatar
Kris Tunetso
I'll have to keep this thread on file. I got my horn working again about a month ago but now I have to hit the button just right to get it to sound. Too soft, too hard, or not on the right spot and I get nothing. Like Goldilocks it's got to be 'just right.'
Maybe doing this will solve it. Thanks.
Old Nov 6, 2015 | 10:13 AM
Capt Ken's Avatar
Capt Ken
Default More info
I did the suggested fix, first set of washer were too big, result constant horn. Next set got it back to original setting, but still very sensitive. Ended up putting thin washers under the ears where the screws are to move the horn button assembly away from the ground contact. Took a couple tries but now have to push firmly on the horn to get it to work.
Old Mar 31, 2016 | 03:55 PM
terry82's Avatar
terry82
ITs now spring .I did the repair.It should have a GM recall repair number .worked great thankyou
Old May 27, 2019 | 10:03 AM
C3wannab's Avatar
C3wannab
6th Gear
Default Fixed!
Thank you for this detailed fix. I had replaced my retainer by the lower contact but once everything was back together I still had constant ground. Turns out my upper contact was missing that insulator/gasket and once installed it works like a charm!
Old May 27, 2019 | 01:35 PM
Goody's Avatar
Goody
Thread resurrection once again... but, if it works, it works.
As a side note, I did some work on my non functional horn a couple weeks ago. By looking at the service manual I was able to figure out that somebody did not follow any directions and it was not assembled properly. I now have a good telescoping column and good horn.
Old May 27, 2019 | 04:20 PM
C3wannab's Avatar
C3wannab
6th Gear
Precisely! 7 year old thread but still very relative. I also learned/fixed the telescoping feature, so win-win.
Old May 29, 2019 | 09:53 AM
RocketNerd's Avatar
RocketNerd
Old Aug 5, 2019 | 11:44 AM
Jim__H's Avatar
Jim__H
Gonna try this today, hope it works!
Old Aug 5, 2019 | 12:46 PM
Bergerboy's Avatar
Bergerboy
[Sorry, couldn't resist}
Old Aug 5, 2019 | 12:59 PM
Jim__H's Avatar
Jim__H
Hey thanks for replying Bergerboy, for some reason now all the photos are showing...
To Sensitive horn - easy fix
