Bracket behind left dash panel
Old Sep 17, 2012 | 05:11 AM
supersonicvette's Avatar
supersonicvette
Default Bracket behind left dash panel
While I had my dash apart on my 69 I found that the bracket that the trip reset cable mounts to had two other unused holes. Any idea's what might have gone there?
http://forums.corvetteforum.com/albu...ctureid=119241
Sorry, haven't quite figured out the whole posting pictures thing yet
Old Sep 17, 2012 | 07:16 AM
Alan 71's Avatar
Alan 71
Hi ssc,
On my 71 the bracket has 4 holes; the driver's side courtesy light is in the largest of the holes, the re-set in one, and the third and fourth holes are unused.
Regards,
Alan
Old Sep 17, 2012 | 11:54 PM
DZRick's Avatar
DZRick
Using Alan's picture in '68 and '69 the opening next to the reset **** would have been used for the optional speed-warning ****. I'm not sure about the 4th opening.
Old Sep 18, 2012 | 12:22 AM
AF_Vette's Avatar
AF_Vette
my 72 has two override valves? 1 for the headlights and one for the wipers as well as the speedo reset and light.
Old Sep 18, 2012 | 08:19 AM
Alan 71's Avatar
Alan 71
Hi AF,
What you're seeing are the overrides for the wipers and headlight doors and the wiper motor control, which are directly below the steering column, and also the bracket for the trip odometer reset and courtesy light which is a separate bracket to the left near the hood release handle.
Sounds like you're o.k.
Regards,
Alan
Old Sep 18, 2012 | 11:41 PM
AF_Vette's Avatar
AF_Vette
Originally Posted by Alan 71
Hi AF,
Regards,
Alan
Thanks Alan
To Bracket behind left dash panel
