upper ball joint boots?
Old Sep 18, 2012 | 12:21 PM
Vette-kid's Avatar
Vette-kid
Default upper ball joint boots?
Im starting to put my suspension back together and I cant figure out how this boot is supposed to install. Do I slide it over the ball join first and then slide them down through the top, sandwiching the boot between the metal? This seems like the only way the boot will really seal and stay in place. Going up from underneath the boot does not seem that it will stay in place very well. True it will have the spindle stopping it from coming off completely, but it seems you could still get debris in there.
I have searched and couldn't really find anything definite on this subject. Thanks for any help...im sure Ill need much more before its done!
Old Sep 18, 2012 | 01:29 PM
Vette-kid's Avatar
Vette-kid
Interesting write up, thanks. Im replacing the ball joints completely, along with everything else, so the a-arms are still off the car and joints not bolted in yet (still need to enlarge the bolt holes...not sure why they send larger bolts with it??). The car is a 78.
Old Sep 18, 2012 | 01:34 PM
oldalaskaman's Avatar
oldalaskaman
the right parts shouldnt need larger bolt holes and the boots will stretch over the ball joint and compress...a bit
Old Sep 19, 2012 | 11:52 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The moog (lower and upper) and federal mogal ball joints come with a larger bolt than the original a-arm hole. Just find a set of bolts that fit the hole and you'll be fine. I'm not sure why either, but they have done so for years. My guess... is that possibly when people drill out the old rivet they enlarge the hole.
Old Sep 20, 2012 | 07:45 AM
Vette-kid's Avatar
Vette-kid
Interesting. The parts are all from Willcox, so Im sure they are correct
Old Sep 20, 2012 | 09:18 AM
oldalaskaman
I'm sure they are also, but when I rebuilt mine with parts from a different vender, no drilling required. good luck
thinkin back, my kit came with the smaller bolts, it was a no name brand though, probably only last 5-10 years in stead of lifetime.
Old Sep 20, 2012 | 03:05 PM
0Willcox Corvette
Former Vendor
I'm not really sure why they send larger bolts... makes no sense to me and again I was just guessing. But they have for a long time.
I missed your other question about the boot... Put the joint in the upper arm and bolt it down and you will be fine. The boot stays on and is pinched between the joint and the arm. On original ball joints it was a different story...
Willcox
Old Sep 20, 2012 | 06:00 PM
Vette-kid's Avatar
Vette-kid
I think im a little confused here still... Just to confirm,
1...slide the boot over the joint, then drop them both down through the arms and bolt it up, sandwiching the boot in the control arm?
or...
2... bolt naked joint to arm, then slide boot in place?
Old Sep 20, 2012 | 09:45 PM
oldalaskaman
I did #2 on mine, but from a different vender, Willcox is on here daily and his crew answers emails and the phone, might be best to ask one of them
Old Sep 20, 2012 | 09:47 PM
Vette-kid's Avatar
Vette-kid
I did. He saw my post as well. For the benefit of others I asked them to reply in this thread. They have been very helpful.
Old Sep 20, 2012 | 10:11 PM
0Willcox Corvette
Former Vendor
On the federal mogul ball joints you received.. I think the boot is left on the joint and installed. Now I'm going to have to check. On the old style moog joints I know you put the joint in then slid the boot on... I just riveted two original joints in last Friday.
Let's hold pat until I can double check this with the shop... I've not installed the USA made FM joints in a long long time... I'd hate to steer you wrong.
Old Sep 21, 2012 | 02:12 PM
Street Rat's Avatar
Street Rat
or...
I just installed Moogs in mine. I used option #2 also.
Old Sep 21, 2012 | 09:42 PM
0Willcox Corvette
Former Vendor
Kevin said naked then boot..
Old Sep 21, 2012 | 09:44 PM
oldalaskaman
butt nekid?
Old Sep 22, 2012 | 09:11 AM
Vette-kid's Avatar
Vette-kid
Awesome, thanks for the clarification everyone....I guess Ill go naked
To upper ball joint boots?
