intake manifold/carb
Old Sep 21, 2012 | 03:43 PM
  #41
pauldana's Avatar
pauldana
Originally Posted by texas jim
You guys are far beyond me in knowledge in ref. to carbs. I just want to know why more guys aren't using Q-jets at the drag tracks. The guys who are winning at the big tracks know their stuff when it comes to carbs, and even though it's harder to dial-in a Q-jet, you'd think they would beable to get the job done. And even though there is little advertisement f/ the Q-jet and therefore less aftermarket hype, if the guys who are "winning f/ the money" would be winning more w/ a Q-jet, wouldn't they be running the Q-jet rather than other available carbs? I know quite afew guys who are very knowledgable and who aren't sponsered, and if they could run faster w/ a Q-jet, you bet they would be doing it. Are Q-jets a bettter application on certain engines and not f/ others? In this day and age, if Q-jets were a faster application, they would be known as such. I personally have had good luck w/ all of them, Q-jet, AFB, Edelbrock, etc., but just like was stated here, the AFB/Edelbrock type design is easier to work on, and the Q-jet took some doing. Just asking afew questions as I know you guys are up on this stuff. Thanks in advance.
a lot of my original thoughts too...this also makes little since to me... these guys will run anything that helps them win.... and none that i know of run a Q
Old Sep 21, 2012 | 03:44 PM
  #42
Shark Racer's Avatar
Shark Racer
I think a major issue w/ the quad is the ease of adjustment. Guys who are running at the track are changing jets multiple times a day. This is a process that takes much longer on a quad than a holley.
Old Sep 21, 2012 | 04:24 PM
  #43
billla's Avatar
billla
St. Jude Donor '14
...and tuning parts availability is poor overall, while Holley parts are available just about everywhere.
Old Sep 21, 2012 | 10:57 PM
  #44
texas jim's Avatar
texas jim
But these guys DO get their cars dialed-in and finished. They would dyno the car and run what runs best. They would have that down. And if the Q-Jets ran that well, then there would be available parts out there also.
Old Sep 22, 2012 | 12:39 PM
  #45
Shark Racer
Well, 850CFM is about the upper limit on what a q-jet can pull. The 8 and 9 second guys won't be running them, and the bulk of the population follows the stickers they see on the side of pro stockers and top fuelers. What more do you expect?
Besides, street drivability isn't all that important in a car that's trailered to and from an event. I think most of these cars are willing to trade idle/off idle response for something that saves them a ton of time dialing in WOT.
Old Sep 22, 2012 | 02:15 PM
  #46
63mako's Avatar
63mako
St. Jude Donor '08-'09
The main thing is ease of adjustment and parts availability. On a strip car and in the dyno room your typical race oriented machine shop can dial a holley in for best WOT operation in no time with readily available parts. In a mostly street application a properly tuned qjet is tough to beat for fuel economy and overall performance. It is one of the best street/strip carbs ever made and worth the extra time and effort to properly tune for your specific engine combination if you already own a good one.
Old Sep 22, 2012 | 10:27 PM
  #47
694speed350's Avatar
694speed350
Originally Posted by Roco71
This is the best deal you could come across. Lars is the "best of the best"
have to agree
