1969 3x2 return spring questions
Old Sep 24, 2012 | 12:49 PM
loflite's Avatar
loflite
Default 1969 3x2 return spring questions
Recently had my L68 worked on and the mechanic can not remember how the return spring hooked up so he made a make shift solution. Unfortunately, I did not pay enough attention to it either. Can any one email me or post a picture of the correct set up. I searched the web and can not find where the spring connects. I know the early '69s (prior to 11/68) had a spring connection on the 1st carburetor stud. This car was later than that. Thanks. Also, did a search on the forum here, and someone posted that it was a good idea to add a second spring, as the factory single spring set up caused wear on the carburetor throttle shaft? Anyone have ideas about that? Thanks again.
Old Sep 24, 2012 | 10:56 PM
69FASTFUN's Avatar
69FASTFUN
The springs is attached to a small bracket on top of the accelarator bracket
Old Sep 25, 2012 | 01:44 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Nice pic Fastfun. That is so clean that you could eat off of it. Beautiful!
Old Sep 25, 2012 | 10:34 AM
loflite's Avatar
loflite
Thanks, that really helps alot!!
To 1969 3x2 return spring questions
