additives/octane
Old Sep 24, 2012 | 01:57 PM
corzatrr's Avatar
corzatrr
Default additives/octane
I finally took the plunge and purchased a 1970 Vette 454. Telling you all I'm excited is an understatement. Here's my question to you gurus. I've read a few posts regarding additives and octane to Lt1 only and not a 454.
This is my first classic..and I don't want to blow it up! The engine is original. I live in Canada and I can access 89-93 octane out here. What do you guys recommend I use? I am basing my question on the fact I think the classics preferred a higher lead content (I don't know what effects it will have otherwise).
Basically, do I need a lead substitute, what happens if I miss it at a fill up?
Do I need a zinc additive or any oil supplements?
Can I use synthetic oil? I wonder if too much of a good thing can be bad!
Old Sep 24, 2012 | 02:07 PM
scottw's Avatar
scottw
First of all, congrats on the new vette. Need some pics as soon as you can.
You can do a search and look up the multiple threads on oil.
Here are my first thoughts on your two questions.
1. Fuel - I would go with the 93 octane. If you can get it ethanol free, I would. Where I live, the closest ethanol free gas is about 55 miles away so I can't do anything about it.
2. Synthetic Oil - If you have the original engine on a 1970 engine that has been using conventional oil, I would stay with the conventional. If it already used synthetic oil and doesn't leak, I would stay with synthetic. You can get a good quality oil that already has plenty of zinc in it without the need of an extra additive.
Others, much smarter than I am will chime in. Congrats again on the 70.
Old Sep 24, 2012 | 03:04 PM
74modified's Avatar
74modified
Congratulation on the new Vette.
Some topics, (fuel, oil, ect.) will bring out all of the experts and their opinions. Read through them and make your own decision. The lead was added to fuel to raise the octane rating, and had a side affect of forming deposits on the exhaust valves that helped to lubricate and minimize erosion of the valve seat. Around the time of lead phaseout, manufacturers started adding hardened valve seats for unleaded fuel. Using a higher octane will allow your engine to be tuned to its maximum power potential. As to the "lead" additives, my opinion, is it depends on the use of the vehicle. Many collector vehicles with moderate use show little valve erosion, but racing, heavy or extended use could cause you to see erosion. If I was going for "heavy use", I would freshen the heads and add hardened seats rather than add stuff to my fuel.
Old Sep 24, 2012 | 04:26 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
93 unleaded gas is fine for your 454. Lead is not needed. No additives are needed. I run Shell Rotella 15W40 in my big block and high compression small blocks.
Old Sep 24, 2012 | 05:56 PM
Paul Workman's Avatar
Paul Workman
Wife's L46 (350/350) with 11.0:1 runs just fine on 93 unleaded. I have a 160ºF thermostat in it, and she runs cool and no knock issues.
I DID have knock issues with a 427 BBC with 11.0:1 compression, used all kinds of additives to little avail, especially as the engine got hot in traffic. In the end it was the 160º 'stat AND dumping the mechanical MDS distributor for a vacuum advance unit. Presto! Gone were my ping issues - after 3 years of putting up with it all that time.
P.
Old Sep 24, 2012 | 06:42 PM
Mike Ward's Avatar
Mike Ward
This.
Don't believe the hocus pocus about needing lead or hardened valve seats.
Old Sep 24, 2012 | 11:28 PM
Limey1955's Avatar
Limey1955
Originally Posted by Mike Ward
This.
Agree. I have a 350/350 and run 92 octane all the time with no pinging. I did get lead additive when I bought the car but no longer use it.
Old Sep 24, 2012 | 11:54 PM
eagle275's Avatar
eagle275
This ethanol fuel has been killing me on my equipment here at home, and probably will have repairs coming along on my vehicles. I've got to llok at my carb on the Vette and see how it looks. Is Staybilt a good additive to use?
Old Sep 25, 2012 | 09:04 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
No fuel additive. No oil additives. High ZDDP oil needed.
Old Sep 25, 2012 | 10:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
http://www.wildbillscorvette.com/OctaneSupreme01.htm
I run this stuff, love it.
Surely wont hurt anything. Lot cheaper than race gas
Old Sep 25, 2012 | 12:57 PM
Mike Ward's Avatar
Mike Ward
Why? What an absolute waste of money. The 'points' of octane they talk about are .1, not 1.0.
A full bottle of that stuff will raise 2 gallons of gas from 91 to 92.6 octane. Big deal. 'Racing gas' is cheap by comparison.
Old Sep 25, 2012 | 01:19 PM
cottoneg's Avatar
cottoneg
Since you may not be sure what was done to the car before you purchased it, listed closely for knock. I had a 350/350 with 11 to 1 or better compression ratio. I Always ran 93 octane. When the engine came apart, the forged pistons had chips from detonation damage.
Old Sep 25, 2012 | 05:08 PM
glen242's Avatar
glen242
I have a SBC 383 with a CC XE274 cam. Calculated static CR is 10.3, dynamic CR is about 8.1.
I run 89 octane gas with no problems.
Run the octane that the engine needs, not what you think it needs.
Intake closing point has a lot to do with octane requirements. Just my opinion, based upon my set up.
Old Sep 25, 2012 | 05:21 PM
flyeri's Avatar
flyeri
Ethanol is hard on equipment, especially small 2 stroke carbs. Most damage seems to happen when the equipment is not used and fuel is not run out of thr carb. It should not be too much problem in your regular driven vehicles. Stabil, Blue Marine grade, works well in the small carbs to combat the effects of ethanol. I would add to my car gas, and runt it long enough to ensure the carb bowl is full, if it was going to sit all winter as many do.
Old Sep 26, 2012 | 01:28 AM
eagle275's Avatar
eagle275
Thanks flyeri! BTW, that car looks very,very familiar!
Sent pm.
To additives/octane
