AC Delco 41240 Fuel Pump question
Old Sep 25, 2012 | 07:22 AM
71-Stingray's Avatar
71-Stingray
Default AC Delco 41240 Fuel Pump question
I've got a mildly built (~400hp) 383 going into my 1971.
I'd like to use the stock fuel lines (supply and return) and was thinking of using this AC Delco 41240 Fuel Pump ... available from Summit (and others). Problem is, I can't find any spec's on it.
Will this pump be up to the task, or do I need to look for a higher volume pump (Edelbrock 1721 or similar)?
Old Sep 25, 2012 | 07:44 AM
oldalaskaman's Avatar
oldalaskaman
what carb. are you using , and then match the pump to the needs of your carb.
Old Sep 25, 2012 | 08:30 AM
71-Stingray
Thanks ... I will be using a Holley 770 CFM
The AC Delco fuel pump is basically the stock pump for a 71.
Old Sep 25, 2012 | 08:37 AM
Jedi926's Avatar
Jedi926
The Eddy 1721 does not have an outlet for the return line. I'm running with an Eddy 650 auto choke carb and I put on a stock fuel filter and have had no problems.
If you really want an Eddy 1721 fuel pump brand new, PM me, I'm not going to use mine. Good luck.
Old Sep 25, 2012 | 08:43 AM
oldalaskaman
your carb. only needs 7psi, roughly to feed it, when you get into constant higher rpm usage, you'll want more volume to keep it full, I like matching pumps to carbs. needs and intended useage. after that it become a personal choice
Old Sep 25, 2012 | 09:08 AM
BKbroiler's Avatar
BKbroiler
The stock replacement pump will work fine. That's what I'm using on my 383.
To AC Delco 41240 Fuel Pump question
