LS1 or 383
Old Dec 31, 2012 | 08:54 AM
  #61
commander_47's Avatar
commander_47
383 is old school. Holley is old school.
82 is old school.
Make mine Old Skool all the way!!!
You can catch me, you can pass me, but you can't outlast me. :-)
Old Jan 1, 2013 | 09:13 AM
  #62
fishslayer143's Avatar
fishslayer143
Originally Posted by dunkin712
Has anyone ever converted their stock 350 crossfire to a 383 and kept the crossfire?
Also, has anyone with a crossfire engine bought the renegage manifold? Any feedback on the Renegade?
stroking to 383 and keeping the Crossfire is a really big waste of time and money.it simply does not flow above 4000rpm ... the Renegade works well , have a friend that got the number 0007 made.. but you could be waiting 6 month to a year for one.
Old Jan 3, 2013 | 04:30 PM
  #63
MalibuVLX's Avatar
MalibuVLX
82 is old school.
Well said!
Mine is 69 and I'll do old skool any time.
Old Jan 3, 2013 | 05:03 PM
  #64
zuendler's Avatar
zuendler
I am currently replacing the blue and red anodized fittings by brass material at my ´69 BB.
The previous owner thought it looks cool...but for me cool is when it looks like it was back then.
What do you think will a LSx look in a C3 in 10 oder 15 years?
How would a C4 engine look in a C2 today?
But anway...you can swap it back in 15 years
Old Jan 3, 2013 | 05:09 PM
  #65
Priya's Avatar
Priya
I've seen a C4 engine in a C2 - only good looking part of the car. The C4 TPI is in my opinion the best looking engine ever made, part of the reason why I plan to put one in my 79.
Old Jan 3, 2013 | 05:30 PM
  #66
gdh's Avatar
gdh
IMHO I think that they will look like dated restos as the C4 engines look in C3's these days. That being said I would love an LSx in my '72 and just not worry about how it looks, I do like the looks of the new Lt1 C7 engine as well. If someone gave me a new C4 engine I would have no problems putting that in my '72 either and just crate my numbers engine.
Old Jan 3, 2013 | 05:58 PM
  #67
MrJlr's Avatar
MrJlr
I don't drive down the street with my hood off very much.....
Old Jan 25, 2013 | 08:08 PM
  #68
Midnightoil13's Avatar
Midnightoil13
Well finally after 4 months the stroker is now in, as well the new DeWitts radiator. Man those SPAL fans are loud. Sounds good and runs nice. Just need some mileage on it so we can then fine tune it.
On another note, I need some expert advice. The battery gauge pegs out the second I touch the gas pedal. I have a kill switch across the battery. With it off I read 13.4 volts and with the car running at idle I read 16.4 volts. Any clues as to whats going on. Also I check the battery with a temp gauge. It was reading 180 degrees and smelled pretty bad.
Old Jan 25, 2013 | 08:19 PM
  #69
Learning_Curve's Avatar
Learning_Curve
Sounds like your voltage regulator is shot, or you don't have the voltage reference wire connected to the alternator.
That bad smell is your electrolyte boiling in your battery. Be careful, an overcharging battery produces hydrogen gas.
Old Jan 25, 2013 | 08:21 PM
  #70
TedH's Avatar
TedH
The day the LS1 install is as easy as installing a Gen 1 in place of my Gen 1, I will seriously consider it. But, that day won't come anytime soon.
Go for the 383 and enjoy!
Old Jan 25, 2013 | 08:55 PM
  #71
Midnightoil13
Gonna have some troubleshooting to do once I find some time
Old Jan 26, 2013 | 02:50 PM
  #72
bluedawg's Avatar
bluedawg
Can you say BOOM!
I've seen two different batteries explode, not pretty.
Old Apr 9, 2013 | 01:46 PM
  #73
Midnightoil13
Hello everyone, it's been a while. So I finally got the 383 in 500 break in miles on it and had it tuned. I'm curious though. This engine is suppose to have twice the HP of the original engine. There is a difference but not that much IMO. I did have the crossfire taken out a while back and it has a 650 Holley Carb now. So I guess the question is did I get snowed on the engine? Do I need a bigger Carb or go to EFI? The transmission is the original automatic with the car, could that be it? Or do I need a different gear ratio? Or some form of all the above?
Old Apr 9, 2013 | 02:00 PM
  #74
cv67's Avatar
cv67
St. Jude Donor '05
Without reading the whole thread what are the particulars on the engine ie head cam intake exh etc etc.
Did you have the distributor curved?
Old Apr 9, 2013 | 02:26 PM
  #75
qwank's Avatar
qwank
Your stock engine is rated in Net horsepower, crate engines are rated in gross. So it more than likely is not double the horsepower, closer to 50% more
Old Apr 9, 2013 | 02:32 PM
  #76
fishslayer143
EFI won t get you more HP than a carb ...you say its double the HP, exactly what is in the new motor? cam specs, compression ratio, manifold,heads etc..... it could be that its built to produce power higher in RPM and the stock gear ratio is defeating that..
Old Apr 9, 2013 | 04:35 PM
  #77
jtalka's Avatar
jtalka
Looking to get about 400hp for my '82 C3. Could get a stroker 383 (crate with warranty) and have a nice Holley Carb already for around $3500 or go with a low mileage LS1 with ECM, Harness, and Transmission for around $6000. Just wondering what anyone else would do to hit that 400hp mark. Any other concerns as well would be appreciated.
I have a 1978 and went the ZZ383 route. It's a bit more $$ than the numbers you were quoting but from my point of view it is the way to go... Like you I had an old Holley 4150 which now sits on top of there. It's been fun to tinker with and tune.. and that motor really pulls. If you go this way, shoot me a note. There are some things I learned in the process which I will be happy to share.
To LS1 or 383
Old Apr 9, 2013 | 05:24 PM
  #78
Midnightoil13
Chev 383 stroker long block 420hp/430ftlbs
chev 420hp/430ftlbs
gm 4-bolt block
gm 350 con rods w/arp rod bolts & nuts
new steel crankshaft
spped pro hypereutectic pistons 9.5 to 1 comp
mahle plasma moly piston rings
camshaft/speed pro
.480/.480-230/230-110 degrees
lifters
pioneer brass freeze plugs
eforce harmonic balancer
pioneer flex plate
mahle tri-metal 780 “iroc” series bearings
double roller timing set
eforce gasket set
melling hv oil pump
gm cast iron cylinder heads
w/1.60/2.02 stainless steel swirl polished valves
speed pro hardened push rods
enginetech new head bolts
bore and hone block with torque plate
deck engine block parallel to main line
re-size connecting rods with arp bolts and nuts
hang and align pistons
line hone engine block
fully balance engine assembly
assemble long block
Old Apr 9, 2013 | 05:36 PM
  #79
Midnightoil13
So those are the specs on the engine. Still stock exhaust manifold. Don't remember what type intake manifold I have. Have no clue what a "distributor curve" is. Unfortunately my mechanic skills and knowledge are just enough to tinker and then screw things up.
Old Apr 9, 2013 | 05:37 PM
  #80
Midnightoil13
If anyone cares here's a link for the '82 vette specs http://corvetteactioncenter.com/spec...l#.UWSJpVcd9R8
