EFE - Heat Riser Valve
Old Jun 3, 2002 | 11:52 AM
pdgourno's Avatar
pdgourno
Default EFE - Heat Riser Valve
On a 1980, does anyone know if is there a vacum line I can block or reverse, or some other method, to make the heat riser valve wide open all the time?
The baffle plate in the valve is rattling. From the actuator near the valve the rod comes up to a vacum line that goes to the TVS. I can pinch that line with a pair of pliers and the noise stops but I do not know if the baffle is in the open or closed position.
I am trying to avoid doing a R&R on the EFE itself.
[Modified by pdgourno, 7:53 AM 6/3/2002]
Old Jun 3, 2002 | 03:40 PM
john's '81 mouse's Avatar
john's '81 mouse
Default Re: EFE - Heat Riser Valve (pdgourno)
If memory serves me correctly, believe the valve is closed with vacuum applied.
That is, the engine should have vacuum in this line when engine is cold, but no vacuum when engine is fully up to operating temperature. If I'm remembering correctly, then all you have to do, is remove the hose from the valve, cap off the valve fitting and plug / remove the vacuum hose.
Old Jun 3, 2002 | 04:11 PM
killain's Avatar
killain
Oldtimer
If you disconnect the line, plug it with a bolt or plug the valve will stay in to open position. It only closes for a short period when vacume is attached to it.
Old Jun 3, 2002 | 04:47 PM
pdgourno's Avatar
pdgourno
Default Re: EFE - Heat Riser Valve (killain)
Thanks killain!!!!!!!
Old Jun 3, 2002 | 04:48 PM
pdgourno's Avatar
pdgourno
Default Re: EFE - Heat Riser Valve (john's '81 mouse)
Thanks John, based on the input from killain your memory still works. Wish mine still did.
Old Jun 3, 2002 | 06:05 PM
Paul L's Avatar
Paul L
That is correct. Default position is open with no vacuum.
Old Jun 3, 2002 | 06:15 PM
TedH's Avatar
TedH
Just disconnect/plug the hose that runs down to the heat-riser. I removed mine entirely when I switched to headers. When disconnected, EFE valve is in 'open' position. Under WOT (and connected) or once engine warms up, it is also supposed to be open (when operating properly).
Old Jun 3, 2002 | 06:59 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
If you need one I have an extra for $15 shipped. JIM
Old Jun 4, 2002 | 12:17 AM
pdgourno's Avatar
pdgourno
Default Re: EFE - Heat Riser Valve (PROSOUTH)
I will try and stop the process for the one I already ordered. $70, ouch.
Old Jun 5, 2002 | 12:31 AM
pdgourno's Avatar
pdgourno
I will have to pass on your offer as the one I ordered has already shipped. Blocked off the vacum line and all is quiet again. I really think they over engineered a method to get the engine warm faster.
Thanks to all for your help.
Is Manchester anywhere near Gatlinburg? G'burg is where I spent the first 12 years of my life.
David
To EFE - Heat Riser Valve
